remove emblem??
  • Thread starter Thread starter ninety1gt
  • Start date Start date Nov 9, 2005
ninety1gt
162
san antonio
Nov 9, 2005
  • Nov 9, 2005
like 5 months ago i got my car painted and i bought, 302 high performance emblems, well i put them on myself and one is crooked, real crooked, and i need tips on how to take it off with out damaging the paint real bad
stang120gt
72
Michigan
Nov 9, 2005
  • Nov 9, 2005
Well this way works and it wont hurt your paint. Use some fishing line and were some gloves, wrap the fishing line around your 2 pointer fingers and put it at the edge of your emblem, then slide it back and forth till it cuts through the 2side tape, if the fishing line breaks rewrap around fingers and keep doing it. Then once you get the emblem off, clean off the 2side tape thats still on the emblem. Then get some new 2side sticky tape from a autopart store. Then put it back on.
This is what i had to do when taking off my emblems, but i didnt put any emblems back on.
If you have any question just ask.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 9, 2005
  • Nov 9, 2005
Add a hair dryer to the above technique and you have the best possible method. Heat the emblem & the area around it to softem the adhesive. I would use some steel fishing leader or fine steel wire because of the heat.
T
txblackmach1
31
  • Nov 9, 2005
im with both of them! but using the fishing line is much less hassel free.
Umby
129
Atlanta, GA
Nov 9, 2005
  • Nov 9, 2005
Definitely go the hairdryer route. A little heat works wonders. Bug and tar remover is good for getting the leftover adhesive.
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Paint and Body Rotten moon roof trim
  • Teen'93stang5.0
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 15, 2026
Teen'93stang5.0
