Removed Smog Pump, Failed Emissions?
  • Thread starter Thread starter 5o5speed
  • Start date Start date Aug 10, 2004
5o5speed
79
  • Aug 10, 2004
I found out that my smog pump has been disconnected on my 91 GT. Will it pass emissions since I still have cats or do I need to reconnect it? I live in a county where they just do the idle test and not the full blown dyno emissions testing.
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Aug 10, 2004
  • Aug 10, 2004
i passed emissions without the smog equipment on my car. Just make sure your timing is at 10* and that the car is at operating temp when they test it.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 10, 2004
  • Aug 10, 2004
It is very dependant on the individual car and the state or local requirements. Some states or areas may have stricter regulations on the amount of pollutants the car can emit.
Running cats with no smog pump will eventually cause the cats to clog up & fail. High mileage engines burn oil that ends up coating the inside of the cats and clogs them. You may not see any evidence of oil burning, but it is still happening if you have a lot of miles on an engine.
The smog pump provides extra air to react with the exhaust and the catalyst and break down the pollutants into CO2 & water vapor. It shuts off at Wide Open Throttle so it doesn’t use any real power when you want all the power you can get. It just doesn’t make sense to disconnect it on a street driven car.
T
tjm73
2,418
Rush, NY
Aug 10, 2004
  • Aug 10, 2004
In Upstate NY the smog pump has to be there and appear to be connected correctly and working. Down state is another story and I don't live there so I don't know exactly what's up.
stangbear427
2,401
New England
Aug 10, 2004
  • Aug 10, 2004
Yes it does. I got sick of them seizing up and leaving me stranded. Happened to me three times with recondishioned pumps and then one more time with a brand new OEM ($325!) Ford one. It's one less pulley in the loop that may give me problems. The power steering is next...
_jb_
808
Michigan, Berrien County
Aug 10, 2004
  • Aug 10, 2004
If you have cats, you might as well hook it back up. I took my smog pump off because I got tired of a "brrrr" sound coming from under my car from where the pipe wasn't connected to the exhaust.
UMDSmith
226
Salisbury, Maryland
Aug 10, 2004
  • Aug 10, 2004
What the hell are cats and a smog pump On the eastern shore of maryland, we don't have emissions. Godbless rednecks and their farm truck ways.
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
C
Exhaust 4 Cats required for smog in California?
  • Codosuarus
  • Sep 28, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
Scottyding73
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
F
Catalytic Converter Calif Emissions
  • frwgt350net
  • Feb 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 2, 2026
frwgt350net
F
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
