What is involved in removing the head unit from an 02 GT? Is it a project or not much of a big a deal? I need to remove it and send back to PC to be resealed. Thanks.
Take off the discharge tubes/inlet tubes. Take the belt off (of the supercharger pulley), remove the 6 or so bolts holding the p1sc onto the supercharger bracket, then pull it off.
I've instlled/removed my procharger on my 99 gt several times and never had to get beneath the car, should be easy enough. the hardest part that I've found for me is the belt removal. the rest is cake!
P1SC is back on the Stang and seems to tracking ok. The seals were replaced. We took our time...used a torque wrench...we'll see how it goes from here. Thanks for you help.
I assumed shipping to Procharger. The cost to reseal and re-ship to me was $433.
Unit leaked slightly after being resealed. I just had the drain plug O ring replaced. Now the unit leaks from I do not know where & has a bearing noise. I'm just about done with Procharger. Nothing but aggravation time and money wise. I'm not recommending PC to anyone. I blame myself...I was warned in advance they have ongoing problems with leaking oil.
I might have someone local try to rebuild the unit or I'm going to remove and live without it. I do not want to put more $$$ into the Stang but if I get crazy enough I'll try a different blower system or Turbo.
If you sent if off to get resealed, did the whole unit get done or just certain parts? Is there any warranty on there work? Thats a bummer, usually I hear they leak due to overfilling of the oil.
Someone in assembly may have made a mistake or used a damaged seal without knowing. I would hope they test a repaired unit if they charge $433 to do it.
There should be enough room in the unit to allow for expansion. If you are boiling the oil then that is another situation altogether. A breather is another something you would have to worry about leaking - not just from expansion but from slosh. I don't think that you should go and reinvent the wheel.
Is there no one that could pull the unit and ship it back for you? While I am sure that they will make good on it, I think your going to have much more of a battle if you wait until spring to do it.. You wait too long you will likely have to pay to do it again and it does not sound like you will be pleased with that.
