Removing altenator/ smog pump bracket
ef200098
123
any special trick to getting this thing off? doing the powerdyne install as we speak and the damned bracket is being stuborn. do i have to take the tensioner off? the bolt right behind the tensionor is off as far as possible. do i just take a sledge to it or what?
mike
Yep, the tensioner is held on with 1 t-50 torx bolt. Go to sears and get one that works with a 3/8 ratchet. It will last a long time, and it has many uses on your car. The seatbelts, etc....
The bracket has 3 bolts that bolt directly to the head. One is behind the tensioner, so you HAVE to take it off, no choice about it. It's really easy, so don't worry about it. Just mark the wires that you take off the alternator, and note how the hoses go on the smog pump.
Scott
Scott
lol you make the wires and hoses seem hard they can only go one way and theres only 1 hose
