Removing Emblems/ Badges
  • Thread starter Thread starter sirpoofington
  • Start date Start date Oct 8, 2007
sirpoofington
11
  • Oct 8, 2007
I've read through a few posts and found conflicting stories. I have a 2004 Mustang GT. I'd like to remove the GT emblem on the deck lid, the Ford blue oval on the deck lid, and the two 40th anniversary badges on the fenders. What is the correct process for removal? Do any of them have the alignment pins/stabs behind them, requiring what sort of body work? Also which ones are stick on only. I've read some posts that say different years have different mounting styles, so if anyone has specific experience to my year that would be very helpful.
Shiroelex
There's nothing worse than aut
728
Westland, MI
Oct 8, 2007
  • Oct 8, 2007
The GT badge on the decklid is the only one that doesn't have alignment dowels, and consequently, holes, behind it. All of the rest of the badges have holes. I just ripped the decklid GT badge off of mine on a whim yesterday. Spent about 20 minutes picking the double sided tape off, and rubbing the glue off with my thumb. It would have been alot easier with goo-gone and some dental floss. That's the best way I have found to remove badges, personally. Douse the badge with goo-gone, trying to get most of it between the badge and the car. Let it set for 5 minutes, then work a long piece of dental floss back and forth between the badge and the car. It will separate the tape from either the car or the badge. Just work your way around the badge in circles, because you can't go straight across. Eventually, you should be able to wiggle it free. All of the badges aside from the one I mentioned have two holes behind them in the car.
Superhereaux
chicks make me feel inadequate
538
South Texas
Oct 8, 2007
  • Oct 8, 2007
i removed the "GT" fender badges on my car using a heat gun, razor blade and a rubber disc "eraser" on a drill to remove the old adhesive.
it worked great for me but i'm sure there's an easier way, goo-gone and floss being one.
not sure where you got your conflicting stories but every 99-04 Mustang has two alignment holes on every badge but the "GT" out back
Casey4s
147
Woodbridge, VA
Oct 8, 2007
  • Oct 8, 2007
I removed my "GT" emblems recently and I used some nylon kite string which worked great. Next time I'll have some of that "Goo-Gone" on hand too. I did try the dental floss but it broke a lot, the light string worked better.
Rear Decklid Finish - Lost Gloss
  • 120rir
  • Oct 1, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 1, 2026
120rir
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
