this weekend i am gonna remove the smog pump and all of the egr gear from my car. i just wanted to check w/ you guys to what all i need to do so i dont over look anything. i know ill need thermactor plugs for my heads and a block off plate for the egr.. and some caps to cap off the extra vaccum lines. but what size belt do i need after i remove the smog pump? i already have an O/R pipe and the air pump tube has been cut and welded shut so that shouldnt be a problem. any other little tips? i also wanna remove the evaprotive canister all i have to do is block off the vaccum lines to it right?
