Removing speedo cable from the VSS
  • Thread starter Thread starter 91AOD5.0LX
  • Start date Start date Mar 25, 2026
First Prev 2 of 2
91AOD5.0LX
I have a slight sag in my rear
5 Year Member
Feb 20, 2021
1,099
1,054
133
Lake George NY
Apr 18, 2026
#21
  • Apr 18, 2026
  • #21
manicmechanic007 said:
Pull the cable completely out from the top (speedometer end) and lube it as you put it back in.
If it's still noisy, that generally means the housing needs to be replaced
Thank you for this! I can try this…
I have to ask though… I already disconnected it from the VSS end of the cable and test drove. It was still making the noise. In theory, if it’s disconnected from the VSS side and still making the sound wouldn’t that eliminate the speedo cable in its entirety because it wasn’t spinning at all after being disconnected from the transmission? I would think the cable at that point was completely dead. That’s why I didn’t try disconnecting it from the speedometer / odometer side first.
Ok, just figured I’d ask if what I did makes sense before pulling the dash but I can certainly do this and see what happens. Always open to ideas and advice. Thank you!
manicmechanic007
5 Year Member
Sep 26, 2017
2,567
727
143
Roy, Utah
Apr 18, 2026
#22
  • Apr 18, 2026
  • #22
Yes, maybe your bushings in the VSS itself are shot and it is what's making the noise
Not common but does happen
You can lube up that VSS inside with some spray grease
Usually, they leak a small amount of trans fluid inside and they never need lube
Reactions: 91AOD5.0LX
91AOD5.0LX
5 Year Member
Feb 20, 2021
1,099
1,054
133
Lake George NY
Apr 18, 2026
#23
  • Apr 18, 2026
  • #23
Ok I will get on this. Easy enough to try.
I appreciate you following up for me!
AeroCoupe
6,250
4,335
183
Claremore, OK
Apr 19, 2026
#24
  • Apr 19, 2026
  • #24
I’m pretty sure it is supposed to be dry graphite but I could be wrong.
91AOD5.0LX
5 Year Member
Feb 20, 2021
1,099
1,054
133
Lake George NY
Apr 19, 2026
#25
  • Apr 19, 2026
  • #25
Yes Sir you’re right. Thank you!
91AOD5.0LX
5 Year Member
Feb 20, 2021
1,099
1,054
133
Lake George NY
Apr 23, 2026
#26
  • Apr 23, 2026
  • #26
Finally the weather was nice and time allowed me to do the cable lube job today. It was worth the try but she’s still acting up. This is puzzling. Thanks for that suggestion @manicmechanic007
Separately, I picked up a new starter motor. No issues with it, just for preventive maintenance. My current one looks original so I’m on borrowed time.
Holy bat man that top bolt! Took me an hour just to find it! Even with the P/S tire removed it’s not visible at all. Had to feel around thru the K-member. Didn’t try the install today, just started the planning. I think this is gonna be a doozie unless I’m missing something.
As for the noise I will just keep the windows down for now. lol
Reactions: gkomo
manicmechanic007
5 Year Member
Sep 26, 2017
2,567
727
143
Roy, Utah
Apr 25, 2026
#27
  • Apr 25, 2026
  • #27
That generally means the housing is worn
Replace the housing for the cable if you can still find one
91AOD5.0LX
5 Year Member
Feb 20, 2021
1,099
1,054
133
Lake George NY
Apr 25, 2026
#28
  • Apr 25, 2026
  • #28
Copy that….. Very annoying problem but solvable so remaining positive.
First Prev 2 of 2
J
Speedometer cable
  • Jimwbx
  • Sep 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2025
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 10, 2026
AeroCoupe
C
1993 airbag module noise
  • Charlie1
  • Sep 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 21, 2025
Charlie1
C
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
