Removing the Center Console!
There are some bolts in your arm rest. There are two little square black pieces of plastic and you need to lift off to access the bolts holding the try in. Once you get those you, remove the tray and you will notice another bolt or two underneath it.
As far as the bezel around the ac control and radio, there are 2 screws near the bottom on the top of a slot. Once those are removed, you just need to pop it out.
