replacing front brake lines???
  • Thread starter Thread starter Allforspeed
  • Start date Start date Aug 16, 2005
A
Allforspeed
264
  • Aug 16, 2005
2 quick questions:
1. i'm trying to replace the front brake lines on my 89 GT with stainless earls ones and i cant get them off? are they reverse thread? everytime i lean on the part where the steel line goes into the back of the bracket underneath the fender and joins with the rubber part of the line i just end up rounding the bolt all to heck??? is it just stuck? do i have to remove something first? i see some C clips on there but it doesn't look like i need to remove them to get the brake lines off??
2. i just drained all the brake fluid out of my brake system and now after researching on here i see that your not supposed to do this because you cant bleed the master cylinder on the car???wtf?? is this true, do i now have to remove my master cylinder??
bubba-dough
1,044
Indiana
Aug 16, 2005
  • Aug 16, 2005
The brake line you are trying to get off is a mutha if it hasn't ever been off. Watch for busted knuckles...ouch...You need a back-up wrench on the one side and just some old fashion brute force on the other side. You will probably round the head too but if you are replacing the line no big deal. Sometimes we have had to use a big set of vise grips clamped really tight to bust it loose.
A
Allforspeed
264
  • Aug 16, 2005
cool bro, thanks for the tip, the part i'm afraid of rounding tho is the head on the hard line. when you replace this bad boy did you have to remove the little C clips that are on the lines? they look impossible to remove, but it looks like they are just there to keep the line atached to the little bracket in the fenderwell??? these have certainly never been off, thats why i figured change em out rather than find out they're bad at 100mph
also is it ok to let the master cylinder run dry? will i still be able to bleed the system with the MC on the car?
any suggestions?
btw: your car looks bad a$$!!! like what my car wants to be when it grows up what times has it run??
bubba-dough
1,044
Indiana
Aug 16, 2005
  • Aug 16, 2005
Yeah the c clip pulls out. I think it has a "handle" on it it pull out. It too is a mutha the first time. We had to take the c clip out on my buddies to give us some movement. Then he had one side of the brake line and I had the other side and we went opposite directions to bust it loose. On my car I left the c clip in. I am not too sure about the mc question. I have busted brake lines and just refilled and bled the brakes and it was fine. On my buddies sn95 swap we had to change the mc anyway so the mc was bench bled. You could always just try filling her up and bleeding them. Also make sure you push the pistons on your brake calipers back into the caliper before you hook your lines up. This will eliminate air in the caliper.
Thanks It just recently got done. She isn't broke in yet. When I get some miles on it, I am getting dyno #'s and track times.
A
Allforspeed
264
  • Aug 16, 2005
did you have to use a flare wrench or did you just use open end wrenches??
thanks for your time!
NosPony
278
Canton, Il
Aug 16, 2005
  • Aug 16, 2005
When you go to bleed the brakes get a vacuum pump for brakes. They are worth a million dollars. Only 20 bucks at harbor freight. I put all new lines in my 89 coupe and blead them by myself with the pump.
F
Fencestang
  • Aug 17, 2005
Definately use a line (flare nut) wrench, as for the c-clips leave them on until you get the fitting loose, otherwise you can kink the hard line when you try to remove the fitting. also soak the threads with WD-40 or penetrating oil like Liquid Wrench and such. Also, the master cylinder is ideally bench bled, but can be done on the car with the vacuum bleeder or a bench bleeder kit found at Napa or the like, it should have a couple of plastic fittings and rubber hose.
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
Aug 17, 2005
  • Aug 17, 2005
You can still bleed the brakes after running the MC dry. It will just take a LONG time to get the air through the system if you do it by hand (or foot I guess). Also, you need an 11mm flare wrench for the hard line in the fender well. Since you rounded it off, sounds like its time for a small set of vice grips. Make sure you grip on the head only and don't touch the threads as your new SS lines may require a deeper thread engagement to fit. Definately use another wrench on the flex line side (I believe 3/4" or 11/16" will do it). As for the C-clip ... just get a flat head screwdriver and put it between the c-clip and the fitting on the flex line and then turn it. This will pop the c-clip out no prob. For reinstalling, I use a large set of adjustable pliers, putting on side on the stainless fitting and the other on the c-clip, while gently closing the pliers. This will put it back into place with little effort. Good luck.
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
Brakes Sealant for passenger side brake line fitting? (Weatherhead 7828)
  • dan50
  • Nov 9, 2025
Fox 5.0 Mustang Tech Nov 12, 2025
dan50
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
