replacing Master cylinder help
  • Thread starter Thread starter bigvino
  • Start date Start date Aug 11, 2011
1 of 2 Next Last
bigvino
259
Corpus Christi, TEXAS
Aug 11, 2011
  • Aug 11, 2011
hey everyone im have a new 93 Cobra M/C and im having difficulty removing the old M/C.. it doesnt want to pry off from the Brake Booster.. any suggestions? i have the brake lines removed from the old M/C.. thanks1
Rick 91GT
Mustang Master
95
99
PA
Aug 11, 2011
  • Aug 11, 2011
you took both nuts off along with the lines, try tapping it with a rubber hammer
bigvino
259
Aug 11, 2011
  • Aug 11, 2011
Yea the nuts are off,,but the m/c doesnt come off... Feels like its sealed to the booster..
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Aug 11, 2011
  • Aug 11, 2011
All that holds it on are the two nuts. Take them off and it should come. Spray some penetrating lube in the studs and tap the end woth a rubber Mallet.
Was the rest leaking? If so, it probably corroded itself to the booster and the booster should prob be replaces as well as brake fluid eats the rubber inside
TenorPlayinGuy
1,208
Canyon Country, Ca
Aug 11, 2011
  • Aug 11, 2011
agreed^
bigvino
259
Aug 11, 2011
  • Aug 11, 2011
no i didnt notice any leaking.. but the paint on the booster was flaking and coming off..
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Aug 11, 2011
  • Aug 11, 2011
Usually happens due to brake fluid leaks....common for The mcs to leak from the bore onto the booster. You'll see a "trail" of peeling paint under the mc leading downwards
bigvino
259
Aug 13, 2011
  • Aug 13, 2011
yup! i looks like im going to have to replace the brake booster as well.. which one Brake Booster should i get? here is my set up:
Front calipers > 01 GT PBR's
Rear calipers > 97 V6,GT mustang
M/C > 93 Cobra 1"
Thanks everyone!
Bryan83taco
554
40
39
SF Bay
Aug 13, 2011
  • Aug 13, 2011
Excuse my ignorance but why are you replacing the booster now? I don't think some brake fluid can destroy a booster. I'm in the middle of my MC upgrade as well. Pry off the MC and slap on the Cobra one.
Lots of people on here get away with using the stock booster and a cobra or 94/95 MC. I'm hoping I fall into the same boat. Let me know how it works out for you.
bigvino
259
Aug 13, 2011
#10
  • Aug 13, 2011
  • #10
thats the problem i have.. the booster and the M/C dont want to separate.
93project
549
52
38
El Paso, tx
Aug 13, 2011
#11
  • Aug 13, 2011
  • #11
I'm also in this situation. 02 PBR, rear ranger drums. and im buying a 95 new MC. What are u doing about the proportioning valve? Mine started leaking bad yesterday. I just noticed today.....
Anyone ditch the stock valve for a new setup?
bigvino
259
Aug 13, 2011
#12
  • Aug 13, 2011
  • #12
are you going to replace the rear drums for disc?
93project
549
52
38
El Paso, tx
Aug 13, 2011
#13
  • Aug 13, 2011
  • #13
No. I have new ranger drums, shoes and hardware installed. The brakes never felt good. Soft pedal, and with the valve leak, I know why its stopped worse than it used to 4 lug. I'm just needing to know what to do to delete the valve.... I'm gonna get the new 95 MC, new fox booster. Can I just use a baer proportioning valve to ditch the stock one?
Bryan83taco
554
40
39
SF Bay
Aug 13, 2011
#14
  • Aug 13, 2011
  • #14
Oh I see. Let some penetrating fluid get there then pound on it with a rubber mallet. Also a few good wacks with screw driver/pry bar may do the trick. I would keep at it because I've heard getting a SN95 booster in the there even more of a pain in the ass. They are a little bit bigger.
Bryan83taco
554
40
39
SF Bay
Aug 13, 2011
#15
  • Aug 13, 2011
  • #15
93project
I'm pretty sure you are supposed to keep the stock proportioning valve when you keep the drum rear brakes. From I've read during my 5 lug/rear disc swap, the adjustable proportioning valve is only needed when you do a disc rear swap.
Do some research on the ranger drum conversion.
bigvino
259
Aug 13, 2011
#16
  • Aug 13, 2011
  • #16
should i get the sn95 bosster or the brake booster from a 87-93???
93project
549
52
38
El Paso, tx
Aug 14, 2011
#17
  • Aug 14, 2011
  • #17
I've heard that modifications are needed to fit SN booster....
I researched the drum set up and here's what I found...
I can use a T fitting for the front PBR caliper lines and an aftermarket proportioning valve for the rear. This works
because I have "mismatched" front and rears.. the 95 master cylinder will provide enough fluid push for
The larger calipers, and a firmer pedal
Bryan83taco
554
40
39
SF Bay
Aug 14, 2011
#18
  • Aug 14, 2011
  • #18
Don't forget about your 3-2 port conversion if your going to a sn95 MC. MM sells a good kit so you wont have to flare any brake lines.
bigvino
259
Aug 15, 2011
#19
  • Aug 15, 2011
  • #19
but i have a M/C from a 93 Cobra...should i get a booster from a SN95 or a 87-93?
Stroked N Blown
52
Oak Hills, Ca
Aug 15, 2011
#20
  • Aug 15, 2011
  • #20
Im surprised that one the experts have not chimed in. lets have more opinions on this. the guy is stuck.
1 of 2 Next Last
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
R
Fox Hydroboost conversion/proportional valve
  • RubyRedNotch
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 20, 2026
RubyRedNotch
R
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
A
Resolved Brake light switch
  • Alabama
  • Feb 24, 2025
4K
General karthief
