I'm in need of a new clutch (thanks to some not-so-unwanted-power
) but at the moment I only have enough cash for the clutch assembly (including new pivot ball, fork, pilot bearing, tob, and clutch quad/adjuster) and not or a new flywheel. Seeing as I only have 18k miles on the car, and only 1500 miles or so have been with the blower, the clutch is only starting to feel "weak", and only 6 trips down the 1/4mile at 330rwhp, do you think my flywheel will be ok if I have it resurfaced ("turned")?
Would it be better to go with a stock replacement flywheel? What is the part number for the stock flywheel for 04 GT? How much are those usually? I could spring for a maximum of an extra $100 bucks; I just don't have the $250-$400 to spend on an aluminum/billet steel flywheel right now
I'm planning to go with a Spec stg3 or an 11" McLeod stg3 kit from MM - will these clutches last substantially longer on an aftermarket flywheel? Will they perform well enough on a stock flywheel? And on the Spec clutch, is there TOB the one to use, or is OEM better?
Thanks - :SNSign:
) but at the moment I only have enough cash for the clutch assembly (including new pivot ball, fork, pilot bearing, tob, and clutch quad/adjuster) and not or a new flywheel. Seeing as I only have 18k miles on the car, and only 1500 miles or so have been with the blower, the clutch is only starting to feel "weak", and only 6 trips down the 1/4mile at 330rwhp, do you think my flywheel will be ok if I have it resurfaced ("turned")?Would it be better to go with a stock replacement flywheel? What is the part number for the stock flywheel for 04 GT? How much are those usually? I could spring for a maximum of an extra $100 bucks; I just don't have the $250-$400 to spend on an aluminum/billet steel flywheel right now
Thanks - :SNSign:
lol Point of post was can I get away with resurfacing, or OEM replacement - or is aftermarket required?
Thus, the Dual Friction recommendation
