access to a press makes it alot better. on the dizzys ive messed with, the gears like to get STUCK pretty good on the shaft. you may need a press to get it off.
as for the pin. when putting it back in, MAkE SURE you get it on right, the hold in the gear and shaft ARE NOT in the center of the shaft, they are offset slightly.
