revving problems
darkarrow
31
i have a 1993 mustang gt vert, and when i accelerate and the engine reaches about 3500-4500 rpm, the engine surges and lurches and wont accelerate anymore. i have replaced the IAC, cleaned the MAF sensor, dumped loads of injector cleaner in the car, adjusted the timing to 12 degrees BTDC, cleaned the spark plugs, replaced the rotorbug, and the dist. cap. and nothing i have done has helped. im almost ready to take the car into a dealership and have them monitor the engine, but not at $130. does anybody know the culprit to the acceleration problem? the car seems to have been losing power overtime so im guessing its electronic and involving fuel mixture and timing, and im not giving up. could it be the crank angle sensor?
Loss of power on a warm engine at higher RPM is usally a sign of a TFI going bad.
Spend 2 cents for a paper clip and save 129.98...
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
i have done the KOEO and the KOER tests and i get no codes from the KOEO test and "car is trying to learn to idle" on the KOER test, i never got a codes for the TFI, but is there a way i can test the TFI, isnt it located on the side of the distributor?
86-93 5.0s mount the TFI on the distributor. It gets hot while it is running due to electrical resistance, engine heat and the hot air from the radiator.
The auto parts stores will test TFI's, but it isn't very reliable on Mustangs. The modules tend to fail when hot. Unless you have a hot air source to heat the TFI, you can't easily duplicate the type of heat a TFI module gets exposed to.
thank you, i replaced the TFI and it seems to have helped with the power issue and revving when the car is hot, but my car still idles at 1100, but when it gets hot the car idles at 1400 rpm. i dont know what causes it, i have replaced IAC, cleaned the MAF, checked for vacuum leaks, replaced all vacuum hoses and so on. I hoped replacing the TFI would fix this problem. The reason is when i unplug the jumper in the wire to the TFI, unplugged like when checking timing, the engine goes from 1100 rpm at idle, to 700 rpm at idle where it should be, does anyone know what could cause the high idle problem?
