rhs heads
this is true i was looking at a variety of heads. afr185's, and canfeilds, and a guy at jpc recommended trick flow 185 cnc's. depends on how much i want to spend really. alot either way and a big decision when ur stuck with all that in them
I'D PASS ON THE RHS HEADS AND GO WITH TRICK FLOW, AFR OR CANFIELD. JMO
Based on what?
What cylinder head do you have now?
What cylinder heads have you run?
I'm asking what foundation your opinion has here.
I own a set, and will go head to head against yours on a flow bench.
Then we'll run them on a dyno.
We'll consider +/- 3% difference a wash.
Not to jack the thread but I am buying some of the 180cc rhs heads regardless of what people say:shrug:
Oh, they will be going on a 331 with a rpm2intake and possibly a 51014 or 51025 camshaft.
A local shop bought a set of there small block chevy heads. They weren't much better than the stock chevy double hump heads. He done some bowl work to them and picked up another 30cfm.
Also if you don't buy the heads complete from them they have cast valve guides, not bronze like in the pic's on the website.
my buddy has a pair of 215s on his cast crank 347. on motor through the 4150 and victor jr it runs 6.70s@101 in the 1/8 mile. we are hoping colder weather and some tuning will get it into the 6.60s. if the 215s are any indication, the 200s should be good to go. i prefer the TFS heads, but the RHS heads are have been proven to run good.
