  • SN95 4.6L Mustang Tech
ride height question
  • Thread starter Thread starter cammngt
  • Start date Start date Feb 16, 2009
cammngt
20
Houston, TX
Feb 16, 2009
  • Feb 16, 2009
I have been seeing a noticable difference in ride height on my car from driver side and pass. side. Almost like it is leaning towards the drivers side more. I finally pulled out the tape measure today and found the following.
DF - 26 1/8"
PF - 27"
DR - 25 3/4"
PR - 26 5/8"
So, the drivers side does sit about an inch lower than the pass. side. Now I know my 220lb ass couldn't be causing this, but could it?? Could I just swap spring from side to side and maybe even out over time? I checked tire pressure and all 4 are 35psi...
Springs are Eibach sport lines with i'm sure 140k mile stock shocks. Maybe shocks are out????
Thanks for the info peeps.
-B
evil281
276
Arizona
Feb 16, 2009
  • Feb 16, 2009
well ill tell u now with my prokit i can visibly see the exact same thing on my drivers side and i weight all of 160 pounds, but my driver side sits lower then passenger and i had these springs installed so no fat guy before me made it this way lol wish i new the answer too
bhuff30
6,037
35
129
Olathe KS
Feb 16, 2009
  • Feb 16, 2009
It's not going to sit perfectly even and that's ok. I suppose you could switch the sides of the springs, but after switching either the fronts or backs, check the ride height again. The rear springs can effect the way the fronts sit too. Or, you could move the battery from the left front to the right rear.
As an example, here is how my 97GT sits and it had over 145k when I took these measurements:
LF: 28" RF: 28 1/8"
LR: 28 1/2" RR: 27 3/4"
It's not leaning to one side, but the mreasurements vary by nearly an inch from lowest to highest.
cammngt
20
Houston, TX
Feb 17, 2009
  • Feb 17, 2009
I can't tell while driving at all. More off walking outside and thinking my tires are flat everyday
joshjwc9
1,095
17
39
Palm Harbor, FL
Feb 17, 2009
  • Feb 17, 2009
I too have that problem, and I am starting to think that it is in the springs, but one of the shops around here told me of the fact that the stock springs on are cars are a soft specific rate, thus causing progressive ones to be more likely to sag or something like that.
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
A definitive answer to the question of how much height Energy Suspension isolators add
  • 2000xp8
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
2000xp8
Tightening upper control arm bushings at ride height dilemma… need some help
  • AnthonyA1234
  • Dec 27, 2024
  • 2 3
6K
Fox 5.0 Mustang Tech Feb 27, 2025
General karthief
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
