Ridiculous vibration
I agree. I'd lean towards something clutch related isn't right.
Especially if this problem only started after those parts were replaced.
I'm gonna work with my mechanic buddy to pop the trans off and double check everything. I just wasn't sure it could be trans if I'm sitting still and clutch pushed in. And I thought a out of balance flywheel would make it feel like the car was coming apart. The higher rpms 4500/5000 almost makes it feel like it smooths out cause it gets vibrating so fast.
Reactions: 91GTstroked
Btw, new parts does not Always mean right parts. Things can be put in the wrong box along the line or made incorrectly.
Here is the post from @jrichker I think you need.
-Cylinder balance test: use this to find dead or weak cylinders:
Revised 09-Sep-2017 Added reminder to write down the stored codes and engine running codes.
The computer has a cylinder balance test that helps locate cylinders with low power output. You’ll need to dump the codes out of the computer and make sure that you have the A/C off, clutch depressed to the floor and the transmission in neutral. Fail to do this and you can’t do the engine running dump codes test that allows you to do the cylinder balance test.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, have the clutch depressed to the floor, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Here's how to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and drivability problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you dump the codes and then you start the engine with the test jumper in place. Be sure the A/C is off, clutch depressed to the floor and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Your 86-88 5.0 won't have a working Check Engine Light, so you'll need a test light.
See AutoZone Part Number: 25886 , $10
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see www.midwayautosupply.com/Equus-Digital-Ford-Code-Reader/dp/B000EW0KHW Equus - Digital Ford Code Reader 3145.
It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $22-$36.
Order it at Walmart for a better price and free shipping
Write down the codes that the computer outputs since they will give you information on problems that are stored in the computer's memory
If you have idle or IAC/IAB problems and the engine will not idle on its own without mechanically adjusting the base idle speed above 625-750 RPM, this test will fail with random cylinders pointed out every time it runs. The IAC/IAB must be capable of controlling the engine speed to run in the 1300-1500 RPM range. Playing with the base idle speed by adjusting it upwards will not work, the computer has to be able to control the engine speed using the IAC/IAB.
Warm the car's engine up to normal operating temperature. With the test jumper in test position, start the engine and let it stabilize. It should flash a 10 and then a 4 and maybe an 11. If no 11, then there are other codes that will be dumped.
Write down the codes that the computer outputs since they will give you information that the computer found when it is running. These are often different from the stored codes.
One of the first tests it does is to open the EGR all the way, this will cause the engine to stumble and almost die. If the engine dies here then you have EGR problems.
To start the cylinder balance test, briefly floor the accelerator past 2500 RPM and let off the accelerator. The engine will stabilize at about 1300-1450 RPM and the cut off the fuel injectors one at a time. The engine speed will drop briefly and the computer will turn the fuel injector for the cylinder under test back on. Then it starts the process for the next cylinder. When it has sequenced through all 8 injectors, it will flash 9 for everything OK, or the number of the failing cylinder such as 2 for cylinder #2. Quickly pressing the throttle again up to 2500 RPM’s will cause the test to re-run with smaller qualifying figures.
Do it a third time, and if the same cylinder shows up, the cylinder is weak and isn’t putting out power like it should. See the Chilton’s Shop manual for the complete test procedure
See View: https://www.youtube.com/watch?v=HDXrkKS4jTE
for a visual tour through the process. There is no voice narration so you have to listen carefully for the engine sounds. I posted the link for the benefit of Stangnet members who had questions about how to do a cylinder balance test. I do not own that video and I am not the creator.
Do a compression test on all the cylinders.
Take special note of any cylinder that shows up as weak in the cylinder balance test. Low compression on one of these cylinders rules out the injectors as being the most likely cause of the problem. Look at cylinders that fail the cylinder balance test but have good compression. These cylinders either have a bad injector, bad spark plug or spark plug wire. Move the wire and then the spark plug to another cylinder and run the cylinder balance test again. If it follows the moved wire or spark plug, you have found the problem. If the same cylinder fails the test again, the injector is bad. If different cylinders fail the cylinder balance test, you have ignition problems or wiring problems in the 10 pin black & white electrical connectors located by the EGR.
How to do a compression test:
Only use a compression tester with a screw in adapter for the spark plug hole. The other type leaks too much to get an accurate reading. Your local auto parts store may have a compression tester to rent/loan. If you do mechanic work on your own car on a regular basis, it would be a good tool to add to your collection.
With the engine warmed up, remove all spark plugs and prop the throttle wide open with a plastic screwdriver handle between the throttle butterfly and the throttle housing. Crank the engine until it the gage reading stops increasing. On a cold engine, it will be hard to tell what's good & what's not. Some of the recent posts have numbers ranging from 140-170 PSI. If the compression is low, squirt some oil in the cylinder and do it again – if it comes up, the rings are worn. There should be no more than 10% difference between cylinders. Use a blow down leak test (puts compressed air inside cylinders) on cylinders that have more than 10% difference.
I generally use a big screwdriver handle stuck in the TB between the butterfly and the TB to prop the throttle open. The plastic is soft enough that it won't damage anything and won't get sucked down the intake either.
A battery charger (not the trickle type) is a good thing to have if you haven't driven the car lately or if you have any doubts about the battery's health. Connect it up while you are cranking the engine and it will help keep the starter cranking at a consistent speed from the first cylinder tested to the last cylinder.
Having an xcam, will that throw off this balance test? Would it be best to try and unplug one injector at a time and listen for changes in idle? I think that's what I read on how to do it manually
Mine passes the cyl balance test with a lumpy letter cam. Unless you are also sniffing the exhaust for O2 and fuel (Not a good idea), the computer test is better. I suppose the manual way, along with testing for each injector’s resistance and click while unplugged would be OK. But following the write up procedures is worth the time it takes to read through several times to fully understand what you need to do.
Also, I have never had a fouled plug or bad wire shake like this description. A flat six I have can blow off three wires on the same bank and run smoothly. Power just drops With each cylinder not helping. A V engine vibrates more with a misfire, but not like it will fly apart like this.
Sorry for the confusion, mine doesn't vibrate like it's going to fly apart it's just an aggressive vibration that comes through the shifter then into the butt of my seat once I go over 3k rpms. The flying apart comment was what I heard about having the wrong flywheel balance.
Yes, it got so bad that it ruined the trans slip yoke.
ed
Had a buddy over and helped me through the balance test and it passed. I appreciate all the info on that from the guys earlier. I was reading that the drive shaft shouldnt have any play going into the back of the trans, am i correct? which mine does, im assuming that is the sign of the bushing being bad? eggsmith, that sound right?
I bought a 93 coupe a few years back, 2.3L, 5 speed. Guy said it had a vibration. Give him $400 for it, trailered it home. I got it home and started the engine. Yes it had a vibration. Terrible vibration, but it ran, poorly. It was running on 3 cylinders. #3 rod was laying on the K-member and a large hole in the side of the block. Believe it or not I drove it around the neighborhood like that until it finally ran completely out of oil and seized. A 2.3 that runs on 3 cylinders is SLOOOOWWWW. The broken rod, the big end was still on the crank but the beam part was broken off and the piston was stuffed up into the cylinder. Non-interference engine; the head was not hurt, valves, just the block and oil pan. I could've repaired it. Nah, 2.3's are given away all the time, picked up a low mile one from a 92 Convertible that a guy gave away when doing a 5.0 swap, dropped it into the car, and drove it for like over 100,000 miles. Good car. And cheap. I like cheap.
  • Hell Yeah!
Reactions: General karthief
