Since I installed LCA/springs/shocks a month ago.. I've been having this squeek syndrome. It mostly come from the passenger side rearend.
Today I decided that I would fix it. I've post about the problem before and found out that it "may" be that the lca and/or the uca is not tight enough. Well I lift the car up and tighten those. Then when I'm done I slowly lowered the car and noticed the same squeek. I tried to pinpoint where it was coming from and I think it's the springs. Any thought on this? If it's the spring that's causing the squeeking noise then what can I do?
