Rim Clearance
  • Thread starter Thread starter underdog225
  • Start date Start date Aug 8, 2007
1 of 2 Next Last
U
underdog225
39
Minnetonka, Minnesota
Aug 8, 2007
  • Aug 8, 2007
Will I have problems if I get 17x9 rims for a 90 lx with a 5 lug swap? I am looking at some black FR500s. Any help would be appreciated!
gruvee87vertgt
20+ Year Stangneter
Oct 7, 2003
272
26
28
Chicago, Il
Aug 8, 2007
  • Aug 8, 2007
NOPE, NOT AT ALL.
unless your tire is bigger than 265 45
if so we can still make it fit.
I fit a 18x10 rim on a 275/40/18.........
U
underdog225
39
Aug 8, 2007
  • Aug 8, 2007
gruvee87vertgt said:
NOPE, NOT AT ALL.
Thanks! I was told that Ford went with little bigger fenders after 91 and that I would have issues runnin 17x9 in the front on my 90.
gruvee87vertgt
20+ Year Stangneter
Oct 7, 2003
272
26
28
Chicago, Il
Aug 8, 2007
  • Aug 8, 2007
yes they went bigger.....
what size tires are u thinking of going with in front? ....there might be a issue in front....I thought u were talking about the rear......
Chuckman
GTFO you fat, heavy bastard
1,604
1,002
173
st. louis, mo
Aug 9, 2007
  • Aug 9, 2007
very true. my '89 rubs a bit on full lock on the fender extensions with a 245/45 on 17x9's. rack limiters may help that problem, personally i just dont turn so far.
shouldnt have any problems in the rear unless you go bigger than a 275. up till then the only thing that may/may not be a problem is the quad shock, you may have to flip or remove it.
U
underdog225
39
Aug 9, 2007
  • Aug 9, 2007
What size tires would not give me any problems?
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Aug 9, 2007
  • Aug 9, 2007
245/45/17 Front
275/40/17 Rear
fiveohwblow
Official Member
2,169
145
155
Aug 9, 2007
  • Aug 9, 2007
Shakerhood said:
245/45/17 Front
275/40/17 Rear
agreed. My exact combo and its perfect even while lowered.
foxmustangman
196
Idaho
Aug 9, 2007
  • Aug 9, 2007
Yeah, i've got 17x8's and they rub on the inside at full lock in the front, otherwise there's nothing wrong.
gruvee87vertgt
20+ Year Stangneter
Oct 7, 2003
272
26
28
Chicago, Il
Aug 9, 2007
#10
  • Aug 9, 2007
  • #10
I have seen 255 45 17 on a non lowered stang with not issues.
I would go with a agressive tire like 245/35
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
Aug 9, 2007
#11
  • Aug 9, 2007
  • #11
The important question here is WHICH 5-lug swap do you have??
If you have SN95 rear disks, you may have issues with 17x9's striking the fender lips over bumps
U
underdog225
39
Aug 9, 2007
#12
  • Aug 9, 2007
  • #12
Is there a way to find out what 5 lug swap it is? I know it still has the drums in the back which will change soon
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
Aug 9, 2007
#13
  • Aug 9, 2007
  • #13
If it has drums you are all set.
What do you have on front?? If it's just the Mark 7 rotors, you may not even be able to run the FR500 up front. The center cap wont fit and you may have clearance issues with the snout of the rotor
U
underdog225
39
Aug 9, 2007
#14
  • Aug 9, 2007
  • #14
They are Powerslot rotors with Hawk pads.
gruvee87vertgt
20+ Year Stangneter
Oct 7, 2003
272
26
28
Chicago, Il
Aug 9, 2007
#15
  • Aug 9, 2007
  • #15
If they have the big hat on the center of the rotors, the rims will probably not fit. I am not familar with those rotors..I'll cross my fingers for ya
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
Aug 9, 2007
#16
  • Aug 9, 2007
  • #16
Most likely no. They may fit with a small 1/16" spacer though, but i hate spacers
U
underdog225
39
Aug 9, 2007
#17
  • Aug 9, 2007
  • #17
Well then what are my options? I would rather not use spacers...
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
Aug 9, 2007
#18
  • Aug 9, 2007
  • #18
Any V6 wheel
94-95 GT 17" tribars
94-98 16" waffle stars
'95 Cobra R's
94-97 Cobra wheels
That's about it for direct bolt on wheels
U
underdog225
39
Aug 9, 2007
#19
  • Aug 9, 2007
  • #19
Mustang5L5 said:
Any V6 wheel
'95 Cobra R's
94-97 Cobra wheels
What would I need if I wanted to run the FR500s? Just spacers?
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
Aug 9, 2007
#20
  • Aug 9, 2007
  • #20
Properly??? SN95 front brakes and spindles
The spacers may push 17x9's too far out. You'll have to test fit them really. It also depends on what brand wheel you purchase
1 of 2 Next Last
M
Rim suggestions
  • mason5.0
  • Sep 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Qtrhrse23
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
C
Fox 1993 LX 2.3 Wiring
  • Coyoteswap93
  • Jul 13, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2026
AeroCoupe
C
Fox Need help identifying brake setup
  • Cypher02xd
  • Apr 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
Mustang5L5
Flushing water from the radiator and block.
  • djj62478
  • Oct 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 11, 2026
CAMTWO1070
