Will I have problems if I get 17x9 rims for a 90 lx with a 5 lug swap? I am looking at some black FR500s. Any help would be appreciated!
NOPE, NOT AT ALL.
unless your tire is bigger than 265 45
if so we can still make it fit.
I fit a 18x10 rim on a 275/40/18.........
Thanks! I was told that Ford went with little bigger fenders after 91 and that I would have issues runnin 17x9 in the front on my 90.
yes they went bigger.....
what size tires are u thinking of going with in front? ....there might be a issue in front....I thought u were talking about the rear......
245/45/17 Front
275/40/17 Rear
The important question here is WHICH 5-lug swap do you have??
If you have SN95 rear disks, you may have issues with 17x9's striking the fender lips over bumps
If it has drums you are all set.
What do you have on front?? If it's just the Mark 7 rotors, you may not even be able to run the FR500 up front. The center cap wont fit and you may have clearance issues with the snout of the rotor
Any V6 wheel
94-95 GT 17" tribars
94-98 16" waffle stars
'95 Cobra R's
94-97 Cobra wheels
That's about it for direct bolt on wheels
