So i don't have chatter in my valve train but see that the procedure for preload is different than what i have done in the past.
I have Probe Shaft Rockers. 1.72
The way a speed shop told me to adjust them is so that the push rod still spins. There is still some pressure on the lifter. I have never gotten chatter this way. Things have worked fine.
Now i see some videos where they take the play out of the pushrod and tighten the adjustment nut 1 full turn. These videos were stud mount with poly locks.
My adjustment is right where the push rod meets the rocker. Not sure if this has any effect.
If anything i would think my adjustments may be too loose. But i don't have any valve train chatter. Shaft rockers dont have any play in the the mounting area. So how is everyone else adjusting theirs??? Should i go and readjust my valvetrain if its working just fine?
