wasn't sure of my issues (engine tapping) replaced header gasket. Went through 20 other issues. It is rocker arms. I know because I ran the engine w/ the valve cover off (Any thoughts on getting oil out of the driveway) and tightened the rocker arms until the tapping stopped. I did this totally un-scientifically just tightening until tapping stops. I want to do it the right way so here is where I need a step by step walk through.
Correct me if I am wrong:
1. remove all spark plugs so I can easily turn engine by hand
2. start w/ cylinder 1 finger in hole cranking till pressure or screw driver in hole until TDC
3. If Exhaust lifter is up, then I am at TDC of exhaust stroke, so tighten exhaust rocker arm just til I can't turn the rod free hand, then 1/4 - 1/2 turn more
If Intake lifter is up, then I am at TDC of intake stroke, so tighten intake rocker arm just til I can't turn it free hand, then 1/4 turn more
4. Repeat for all other cylinders.
Am I missing anything?
Also, serious about the oil in the driveway. Feeling kind of like the neighborhood redneck after spilling half a court in the driveway today.
