rockerarms loose when valves are closed?
z2o_what
309
princeton, WV
i have a 88 roller shortblock, with D0oe 351 heads, and tfs stage1 cam that i am building. when the valves are closed the rocker arms have a little side-to-side play.... is this normal for stud mounted rockers, or do i need longer pushrods?
I am thinking you need longer pushrods. You shouldn't be able to move them much if any if they are installed correctly. When the valves are closed, do you have up and down play in the pushrod? Are the lifters in their fully extended state?(plunger ALL the way to the top of lifter).
This is tottaly normal. Adjust them the proper way and dont be paranoid. If you have solid lifters you will get some valve train noise during operation but dont be alarmed. If you have hydraulics, they will chatter on strtup till oil fills them but it will go away after just a few seconds.
there may be some up and down play on a couple but its not alot lot. maybe 1/32"
some of the plungers are up and others are down.
i see what you are saying, and im probally going to at least run the engine with these pushrods to see what happens.
use the proper lengths. If you go longer than recommended your gonna get an expensive surprise
valves have to be adjusted on chevys, so why wouldn't that work?
Your lifters are probably just bled down. What you need to do is readjust first before you go buying pushrods. TDC, take to zero lash and then 3/4 turn (or torque if pedistal mounts) . Your lifter plunger should compress about .030. I think the small amount of play you're feeling up and down is probably the lifter plunger moving. When you start the engine that play will be gone.
