I'm in the process of getting one welded up...
They actually told me that welding to the floorpan was a bad idea and that sandwiching the floorpan was better and bolting it on. One of the techs also suggusted "stich" welding the bottom plate on. I thought that wasn't a bad suggustion and will probably do that.
I've been having problems getting an honest quote actually... but hopefully something will happen soon.
I don't really see why, if you sandwiched the floorplates using grade 8 nuts and bolts, it would be any type of problem. However, I would, and am going to, weld the rear braces on there.
If you think about what's actually involved in welding the whole plate onto a thicker* weld point, you should be able to see many advantages including more contact area. Instead of four bolts holding the rear braces together, there's about a 24" welded seam around the plate (assuming 6" plates) so it's a much greater area. I believe all yeild stress/ breaking points would be higher with good solid welds as well. Not so much with the welds on the floorpan though, considering you're welding on such thin metal.
I'm planning on getting some MM full length subframes and tieing in the rollbar to the subs... don't have to worry about the rollbar ripping through the floorboard that way!
hope that helped some...
-Chris
