Roll Cage Question
  • Thread starter Thread starter ImportEater98
  • Start date Start date Nov 13, 2004
ImportEater98
708
Worcester, MA
Nov 13, 2004
  • Nov 13, 2004
As you may know i am putting together a trunk car. The car is completely stripped. I am in the process of puttring the rearend and front suspension/brakes in. I am at the point, with the interior gutted to absolutely nothing, where i am thinking roll cage. I want to get it certified, so i'll be subbing out the work to a shop that installs them. Should i put the full interior back in before i send it to the shop, or should i set it up while its gutted?
Also while I'm on the topic, what sort of modifications/cutting to interior panels must be done? I am probably going with a competition engineering 8 point set up. Says in the catalog that its custom fit, no cutting, or notching. I know that means the cage is custom fit, but what holes need to be made?
Any help/advice on this subject would be appreciated, as i plan to order the cage if that is, indeed, the next step.
Thanks!
-John "Importeater"
NosPony
278
Canton, Il
Nov 13, 2004
  • Nov 13, 2004
Well it depends if u want full interior or not first off. I went with my interior in mine. It is a race car and a weekend cruiser. I only put my door panels on and my seats in (front and back). I had the guy bend the cage to fit my interior. I had the back bars go through where the speakers are in the notch. I also used a competition engineering 8 pt cage.
ImportEater98
708
Worcester, MA
Nov 13, 2004
  • Nov 13, 2004
Well i am going to be running door panels, dash, center console, and rear interior panels (the ones under the sail windows). I am however going to run a rear seat delete, and a very minimal stereo system. Most likley just putting speakers up front. So i guess you could say full interior minus rear seat.
TIMMY2734
1,330
Queens, NY
Nov 13, 2004
  • Nov 13, 2004
From what ive been told on numerous occasions, the comp engineering kit needs alot of cuttign and notching. Look at skinny kids, wild rides and wolfe.
bln92cpe
158
Los Angeles, CA
Nov 13, 2004
  • Nov 13, 2004
I have a 92 coupe with no back seat and minimal stereo because its so loud..I found a company called LINK that fabricates susb, sheet metal and roll cages for off road vehicles, he is gonna fab a 8-10 pt cage for the true all business look, i expect to pay near a thousand bucks for him to do it right and re install my interioe.
A
autoXr1
1,838
Michigan
Nov 13, 2004
  • Nov 13, 2004
So, you drag racers just weld in a cage without welding the seams on the unibody? Anyone have issues with components tearing apart from the unibody?
ImportEater98
708
Worcester, MA
Nov 13, 2004
  • Nov 13, 2004
Im sure that will be a nice job for a grand. I am not looking to spend a grand. Hell, i don't even want a roll cage, but the car i am building, due to IHRA rules, is going to need a cage (11.49 ET or quicker). I just want something that will pass tech, and not break the bankroll, ya know?
5.0 HOtrain
2,247
New Hampshire
Nov 14, 2004
  • Nov 14, 2004
http://www.wildridesracecars.com/cages.html
Pricey, but the claimed fit is worth the money in what it will save in aggrivation. I'm going to buy one over the winter.
mike.
5.0 HOtrain
2,247
New Hampshire
Nov 14, 2004
  • Nov 14, 2004
I was going to tie my cage into the lower torque supports and just weld the seam on the upper supports. Lately I've been thinking of just doing the upper supports. Have you seen components tearing of off the unibody before
mike.
Progress Thread Roll cage and LS swap?????
  • 78mIIman
  • Dec 30, 2024
1974 - 1978 Mustang II Talk & Tech Mar 30, 2025
greenflash79
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
