Roll Cages, Subframes and other junk...
Busted07
I need my gorilla to be about an inch longer.
Nov 15, 2005
I have my interior stripped out now, and since im guessing i should be in the 11's on the bottle, im wondering what the rules are as far as how many points the roll cage has to be... i thought it was anything faster than 12.99 you had to have a 4 point, and anything faster than 10.99 and under you had to have a 6 point. can anyone clarify this for me?
At the same time, im going to be installing subframe connectors. probably the XL full length ones from maximum motorsports unless someone has a better suggestion.
do the roll cage and subframes attach at the same points? as in being welded together, or is there anything i should know when i get them both in the mail and ready to be welded?
how far up does the little oil pump drive shaft clip need to be on the shaft?
The clip needs to be far enough so you have proper clearance when the dist is installed. Install the dist on the block, put the shaft in, mock up the oil pump, you should be able to move the shaft up and down atleast .080" then pull the dist out and make sure the shaft doesn't fall out of the pump, if it does, push the washer down a little. All the washer does is hold the shaft in the block/pump if you turn the motor upside down.
If it binds in the dist then you will need to trim the dist bottom a hair to gain proper clearance.
Hardtop 11.99-10.00 (min of 6 pts) Depending on the design of your bar it may or may not connect to the subframes. Fuell length or through floor subs are the best options.
I'd go with through-the-floor subframes because they connect to the roll cage much tighter, and go with at least a 6 point (honestly...i think 4 points are a waste of time to strip your interior for). I like having the back two bars connect to the rear shock towers instead of to the floor board where you often see them. This will stiffen up the rear end a LOT.
Thanks for the info.. i really appreciate it.. I am kind of budget minded about the roll bar and the sub frames... but i dont want something made out of complete junk. could you recommend a place to get them from? i was thinking about the 6 point from competition eng. or from maximum motorsports... and the MM XL full length subframes.. do you think these would be a good choice?
im not against getting a 6 point... and honestly i stripped the interior out because the carpet stunk, and im needing to powerwash it, and whilei had it out, im going to put a cage in, subframes and driveshaft loop. i like the idea of the roll bar mounting to the shock towers as it will leave me more room in the hatch for the battery and bottle etc... do you know a website or a manufacturer where i could look at these?
You probably should go to the NHRA website and look at the roll bar and cage criteria. I am headed to a cage and it iseems a bit more complicated than I anticipated.
I think, by definition, a roll bar is a 6 point unit. Two front tubes, two points for the hoop and two for the rear struts. Kickers on the hoop may be required.
That goes from 11.99 to 10.99 only, I think. Or maybe to 11.49. Gotta check.
I would go with a full 8/10 point unit, but it appears that you have to pull the windshield to weld it. And I don't want to do that right now.
It also appears that once you put in a roll bar, you have to have certified seat harnesses, a seatback support, etc.
Anyone else up on how to do all this?
I got the idea from Maximum Motorsports...before i saw theirs i always ran them to the rear trunk area. I guess it can be done a bunch of different ways. I think the coolest would be to make the bars going to the rear shock towers X in the middle...that would help stiffen things up, but you won't see a kit like that, you'd have to fab it up yourself.
Maximum has the only bolt in cage that is NHRA legal. Although it's a bolt in, the mainhoop needs to be welded. It's a nice kit at a great price. You can get it with low rise removable door bars. It's very functional and convenient. Plus you can weld it in too. I've seen a lot of guys locally using them.
I ordered mine today. You have to be very specific in what you want. i talked to both wolfe race craft and Maximum Motorsports. The one ROLL BAR from wolfe craft is not NHRA legal because there are bends in the 2 rear support bars. To be NHRA legal, the 2 rear bars cannot have any bends. Wolfe racing has ROLL CAGES that dont have any bends in the back 2 bars and are NHRA legal. Wolfe also has pre-fabbed X braces for the back like SS_302 was saying . you can go to thier site and customize your roll bar, but i highly suggest calling them as well before you do. i was about to spend 4 hundred bucks on a roll bar from them that was not NHRA legal. I talked to maximum motorsports, and they seemed to have the better deal for me. I got a 6 point roll bar, with a weld in center brace (the bar that goes behind the front seats that you can attach the seatbelts too..... it has to be welded to be NHRA legal, but you can get the bolt in center bar if you dont plan on running at the track) with swing out door bars for 399.00. The main reason i chose MM over Wolfe was for these reasons:
1. Wolfe said it would be several weeks before i got my cage because thier tubing was on backorder.
2. You have to pay extra to Wolfe to get the cage "jig notched" (which is just where they cut out the notches in the pipe so you just hold the pipe there and weld it. that is already included in the MM piece.
3. The MM piece has 2 tubes on the halo that the 2 back pipes attach to with bolts, so you can fab it up, bolt it together how you want it, pull it out of the car, and weld it outside of the car.
4. I liked the idea of the low-slung door bars that Wolfe offered, but the MM guy made alot of sense to me that the regular heigth door bars that swing out are safer in case you do have a side impact crash.
5. MM was alot nicer to me in general on the phone and took thier time explaining everything i had questions about. the guy at Wolfe made me feel like i should have known the answers to everything i was asking, and i was wasting his time.
This was just my experience, but i thought i would throw in my 2 pennies. If you guys have any questions, please let me know.. i spent about 4 hours today researching before i purchased, so i might be able to help with some questions.
Here's a pic of the rear section of my chassis, you can see the old "X" brace that was part of my roll bar. I cut out just about everthing other then the main hoop and X brace and built on to make my SFI 25.5 spec chassis, which is certifed. Te X brace is an excellent idea, it adds the support in one of the weakest spots in a Fox and really helps transfer the stress to the needed points.
