i have 1.6 ratio roller rockers and when u give it gas they get real loud like a taping noise i took the valve cover off to see if they were lose but there not is this just common with roller rockers i dont kno please give me some info thanks jj
i used harland sharp 1.6 roller rockers, no loud tapping noises, but the manufacturer did say that roller rockers are a little noisier than factory stamped rockers. sounds like they are a little loose or your lifters or lifter is failing.
The FMS ones from my experience go clackety clack, its normal, just a little louder valve-train. If you havent removed or modified the splash guard on the VC then you might get some contact. Or maybe you need some lifters.
