  • SN95 4.6L Mustang Tech
Rolling fenders
  • Thread starter Thread starter Shiroelex
  • Start date Start date May 10, 2008
Shiroelex
There's nothing worse than aut
728
Westland, MI
May 10, 2008
  • May 10, 2008
I really need to roll my rear fender lips due to a recent rim and tire acquisition, and can't remember how the DIY method went. I had an old BMW years ago that I rolled the lip with a baseball bat and a heat gun, but don't know if that would work well enough and safe enough on my car. Does anyone have any ideas?
forum155pl
520
the 509
May 13, 2008
  • May 13, 2008
i tried a hammer going really slow with a torch and my paint was tottaly cracked when i got done.. and i didnt get it too hot i know.. spencive mistake
the body shop used a beadroller and repainted, but i dont think that would work for you cuz i bet it messes up the paint when they do it
98COBRA281
1,348
30
59
Port St. Lucie, Florida
May 13, 2008
  • May 13, 2008
i need to do this to. my tires are all chunked up aroung the out side from hitting the 1/4 panel..... damn wheel spacers
geoffsgt
176
Baton Rouge, LA
May 13, 2008
  • May 13, 2008
Sounds like something you really wouldn't want to DIY unless you really knew what you were doing.
TrueBlue03
372
Bay Area, CA
May 13, 2008
  • May 13, 2008
use one of those fender rollers.
Several shops around here advertise fender rolling and they use one of these:
I just used a hammer and big pair of pliers....and ended up with my fenders sloppily rolled, cracked paint and blood all over the tools and my driveway .......
925BayArea2v
Bay Area
May 14, 2008
  • May 14, 2008
yea that fender roller is what 04sleeper used on his termi. looks great with a wide wheel. if u can locate his cardomain, i believe theres a link in his sig, he has pics of him doing it.
mixedbreed02gt
Banned
Oct 6, 2007
Nashville, TN
May 14, 2008
  • May 14, 2008
i had my mechanic cut the lips into little strips and use a mallet to pound them up so it looks rolled, didn't come out so great, but I'm gonna a body shop fix it when I take her to get repainted, and have them just make it look like the edges are rounded off. I idont know why the idiots at Ford couldn't have made them rounded off to begin with, they had to know that people were gonna put bigger wheels and tires on there cars.
forum155pl
520
the 509
May 15, 2008
  • May 15, 2008
now that is the coolest tool ive ever seen..i wonder why you would want to roll the front fenders tho.. i thought they came rolled from the factory
mixedbreed02gt
Banned
Oct 6, 2007
Nashville, TN
May 16, 2008
  • May 16, 2008
99-04 did not come rolled. when you use sportlines or other extreme lowering springs with a 315/17/35 or wider on a 99-04 mustang, when you hit a bump the tires will travel up and over to hit the sharp edge of the fender well which in turn shreds the outer edges of the tire...I'm going to upgrade from 315/35/17's on a pair of 17x10.5" wheel to a pair of 305/35/18's on a pair of 18x10.5" for the rear...I will get the better look in back, and not have to worry about the fender problems anymore.
04sleeper
2,674
14
89
Dallas, TX
May 16, 2008
#10
  • May 16, 2008
  • #10
No need to look it up. I have tried the hammer method, the baseball bat method and now the correct and only way to do it, the Eastwood Fender Rolling Tool method with a heat gun.
It is the only real way to roll the fenders EXACTLY the way you want it without destroying the paint.
Here's some pictures of when I did mine. It came out great. I just used a heat gun for the paint to keep it pliable and just took my time. I have now done a few dozen cars all with the same results.
mixedbreed02gt
Banned
Oct 6, 2007
Nashville, TN
May 16, 2008
#11
  • May 16, 2008
  • #11
^ wish I had had that done on mine...that looks clean.
O
Backuplamps
  • onemore1987
  • Jun 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 5, 2026
onemore1987
O
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Parking brake cable
  • 78 Mach1
  • Apr 21, 2025
1974 - 1978 Mustang II Talk & Tech Apr 30, 2025
78 Mach1
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
