most people dont know anything about it, that is what we are looking to change. what kind of gains are they claiming, cause that thing is quite a bit more expensive than most screw/roots superchargers
they had an 08 bullitt at sema that produced 500+ rwhp. some of the others i have seen have been in the 450 range.what kind of gains are they claiming, cause that thing is quite a bit more expensive than most screw/roots superchargers
the efficiency is competitive with turbo setups. Rotrex uses a 7:1 drive, which allows for higher impeller speed.The kit is more complete than others I have seen. I mean that front plate with idlers and tensioner alone is pretty expensive, massive water to air cooler, cooler for the rotex unit (no taping the oil pan).
What I don't get is why the special centrifugal supercharger, the only real advantage the rotex site says is less noise?
Dan
They don't say anything about upgrading the fuel delivery other than increasing injector size.
There is a write up on a install on I think Modularfords....I am going to see if I can find the link.
Hmm cannot find it ATM..but it was on a forum I read all the time. I remember because I was looking for E-Force numbers. The guy that did it had Youtube vids and everything. It made very nice numbers, and was a very clean and easy install. If I find the thread, I will post it here
Edit: Found It
Forced Air Performance Build - ModularFords.com
Good write up
I am looking reeal hard at this Kit. I have a deal in the works for a Supershaker that will fit me perfectly. I have a cdc shaker now
I been told that 430~450 at the wheels is when the stock pump gives out. So I would guess anything pass and its time to upgrade. In most cases, if you want to be at 450~460, I been told a KB-BAP will do the trick safely
I agree, that is one of the most important parts of going FI. lean = BOOM!!Anything over 450 and you should upgrade the pump. I have no experience with the BAP - I went with dual pumps. Will probably do the dual BAP when I do a forged engine. I wouldn't do FI without addressing fuel delivery - you don't want to run lean especially with stock internals.
I agree. 4 hours is crazy! Most people take that just to install nitrous. So 4 hours for them means 10 hours for me, maybe 8 with your write-up. Still means I can get it done in 1 day!![]()
Heath mentioned it would be needed, but i agree, mentioning it on the website would be a good idea. he said they will be working on a new site soon, so they may be holding off on updating the current site.I guess I can understand why they don't include fuel upgrades, but they definitely should note that it's needed.
Khyron has a saleen blower. i believe he is running the 475hp kit with a BAP. he said he runs a little rich up top when on the dyno. BAP seems like an inexpensive option, but almost seems like a band-aid instead of a soltion.I would definitely do it for anything over 400 HP to be safe. I'd rather have extra fuel available, then not enough and blow the engine.
who knows, I may go that route, depending on funds.here is a good read from HOTROD magazine, though i am not sure of the date of this article.
The Rotrex Supercharger Revolution | Hot Rod Magazine Article at Automotive.com
if they still need a car to check out, we may be able to work something out!![]()
