Engine Rough Cold Start
timjimmy
215
12
29
Clarksville, TN
I have an '06 GT with Kooks headers, catted x-pipe, Detroit Rocker cams, FRPP intake and throttle bottle, C&L Racer intake, Brenspeed 93 octane tune, and Performance Automatic 2800 RPM torque converter. For about the last 8 months I've had an issue where, when starting the car in cold or wet conditions, if I shift into drive without letting the engine idle and warm for several minutes the engine will die. It then requires throttling the engine to get it started and it runs rough, requiring me to feather the throttle for a few seconds until the engine smooths out. Today, in sunny, 50 degree conditions, it took me probably a dozen starts before the idle smoothed out and I could take off. This time, the engine would even choke and die in park unless I throttled it. Upon starting, it would release a cloud of smoke and the exhaust had a pungent, sharp smell. It will also smell slightly of fuel. Ordinarily I would think it was a fuel issue, but I'm not getting any check engine lights. Could this be an issue with the tune? I'm running stock style flags with stock gap, and factory injectors and oxygen sensors.
  • Sponsors(?)
cmann
38
57
Have you cleaned your throttle body lately? A dirty TB can cause all kinds of idle and drivability issues.
racerraj
482
30
39
Dickson, TN
Tim, My 06 GT is stock and does that, though maybe not as much. It was worse with the factory plugs. I run Champion 7989s and it got better. When it started doing it again I pulled the plugs and closed the gap some (Seems like I went down to .043, but I will verify. Anyhow, it does it less with a tight gap.
timjimmy
215
12
29
Clarksville, TN
It's only about 8 months old, but I'll pull it and check.
I put Champions in during August 2013, but I'll check the gap.
timjimmy
215
12
29
Clarksville, TN
Sounds like a problem with the tune especially for cold start, open loop operation.
That makes sense. It seemed like an O2 sensor problem except it hasn't tripped any codes. I'll give Brenspeed a call after the holidays. Come to think of it, it did start back in March when I installed the newest tune with the manifold and throttle body.
Thread starter Similar threads Forum Replies Date
B Cold Start Rough Idle Fox 5.0 Mustang Tech 9
0 2003 Ford Mustang V6 3.8L gets around 12mpg and seems to shake a bit when started cold and has a bad rough idle when warm SN95 V6 Mustang Tech 5
J Engine 92 mustang rough cold start Fox 5.0 Mustang Tech 3
1 92 Gt Rough Idle On Cold Starts (long) Fox 5.0 Mustang Tech 2
fiveoho Cold Start - Rough Idle And Blue Smoke ? SN95 4.6L Mustang Tech 1
5spd GT Where would you start? Runs rough when cold/great when warm - no codes KOEO Fox 5.0 Mustang Tech 10
B Rough Cold start and error code P0607 2005 - 2009 Specific Tech 4
M Rough Cold Start SN95 4.6L Mustang Tech 5
J rough cold start on my 85 gt Fox 5.0 Mustang Tech 5
JTGrant Runs Rough at Cold Start 2005 - 2009 Specific Tech 18
8 A possible solution for anyone having rough idle/cold start problems Fox 5.0 Mustang Tech 0
T Rough Idle, terrible cold starts Fox 5.0 Mustang Tech 20
2 Rough when cold, no start when hot Fox 5.0 Mustang Tech 10
T Running rough when cold Fox 5.0 Mustang Tech 5
S Rough Idle While Cold 1994 - 1995 Specific Tech 3
tjmi69 1989 Fox Runs Rough When Cold And Code ?s Fox 5.0 Mustang Tech 28
K Idle Rough And Will Not Idle Cold 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
M HELP New starter and disengaging and running rough when cold Fox 5.0 Mustang Tech 2
N rough idle when cold Fox 5.0 Mustang Tech 7
S running rough in cold weather SN95 4.6L Mustang Tech 9
africansnowowl Engine Another rough idle thread Fox 5.0 Mustang Tech 7
93silverlx50 Engine Car in limp mode, fuel spitting out of tailpipes, missing rough idle Fox 5.0 Mustang Tech 9
markinms Engine surges, cutouts, rough running during acceleration - Help Please! Fox 5.0 Mustang Tech 5
C Engine Gray smoke from exhaust. Smells like gas. Fox 5.0 Mustang Tech 15
B 1999 3.8 V6 rough start and slight miss SN95 V6 Mustang Tech 0
Motorsport71 Engine Ignition Timing Issues 1985 Fox Fox 5.0 Mustang Tech 2
9 Engine 92 5.0 Running Rough Fox 5.0 Mustang Tech 8
R Engine My 95 gt idling rough 1994 - 1995 Specific Tech 5
G mustang running rough after car wash 1996 - 2004 SN95 Mustang -General/Talk- 10
MSTNGGRL1995 Rough, loping idle and random attempts to die 1994 - 1995 Specific Tech 1
K Engine New Built Engine - Rough Start and Idle Surge Fox 5.0 Mustang Tech 3
Sampinator Hard downshift OD to 3rd 1996 - 2004 SN95 Mustang -General/Talk- 1
E 2010 Mustang GT - randon, intermittent, fresh hard starts with rough idle. 2005 - 2014 S-197 Mustang -General/Talk- 0
Xenogenesis Engine Idles rough, misfires at idle, smells rich, but codes say it's lean on both banks SN95 V6 Mustang Tech 9
J 93 mustang breaking up during acceleration 2.3L (N/A & Turbo) Tech 11
S Installed new intake and now car idles rough and turns off 1996 - 2004 SN95 Mustang -General/Talk- 7
J Engine 93 lx 2.3l runs terrible 2.3L (N/A & Turbo) Tech 9
T Engine 1994 mustang gt Rough idle, misfire under acceleration 1994 - 1995 Specific Tech 2
evintho Engine '93 running rough, especially at low rpm's and idle. Fox 5.0 Mustang Tech 1
D 1994 V6 rough idle after head rebuild 1994 - 1995 Specific Tech 0
P Carb, Fuel, or Ignition issue? Intermittent running rough 1965 - 1973 Classic Mustangs -General/Talk- 15
90-06stangs Rough idle. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
J 04 GT New intake manifold and car now has a rough idle 1996 - 2004 SN95 Mustang -General/Talk- 5
P 95 mustang gt running rough 1994 - 1995 Specific Tech 0
LarsD What's it Worth? Whats my 91 Hatch worth roughly? What is it Worth?!?!? 18
R 2000 mustang runs rough and dies when warm SN95 V6 Mustang Tech 10
P Just arrived with a 1965 289 and a 1973 Mach I - and a vacuum leak solved The Welcome Wagon 1
D 1997 4.6 runs rough SN95 4.6L Mustang Tech 1
K What's it Worth? Seeking rough valuation on manual 1967 Coupe w/ 351 Windsor What is it Worth?!?!? 2
S Engine 5.0 Running Rough (1990) Fox 5.0 Mustang Tech 1
