  • SN95 4.6L Mustang Tech
Rough idle, worse MPG, dying at red lights, shaking....
  • Thread starter Thread starter HurricaneJesus
  • Start date Start date May 1, 2009
1 of 2 Next Last
HurricaneJesus
160
Springfield
May 1, 2009
  • May 1, 2009
I was getting around 23MPG now I'm at around 16. Shaking happens between idle and 2500 RPMs. Doesn't seem to be burning oil. I let a guy look at it and he said it seemed like a bad coil but when he changed said coil, another one would act up, and so forth....Occaisionally the car will shut down and come back on voilently, then I'll get a "CHECK FUEL CAP" error light. I'm also getting a whistling sound at times when I get on the gas.
So far I've cleaned the IAC, MAF, and throttle body, and ran some fuel injector cleaner through the gas tank. It's lessened the problem but not totally eradicated it.
Everything on the engine has 15k on it aside from the intake manifold, TB, MAF, which has 110k.
joshjwc9
1,095
17
39
Palm Harbor, FL
May 1, 2009
  • May 1, 2009
First of all, year of the car, and mods done to it?
Pearl02
496
Kansas City
May 1, 2009
  • May 1, 2009
Along with that, are there any check engine codes? Pearl02.
HurricaneJesus
160
Springfield
May 2, 2009
  • May 2, 2009
02 GT with 110k, 03 block and heads with roughly 15k
cold air, 75mm TB....think that's about it, engine-wise.
isjoining
143
Orlando, FL
May 2, 2009
  • May 2, 2009
maybe check and see if you have vacuum leaks?
Jinx
I like cats, cats like me. Cats and I fully agree.
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
May 2, 2009
  • May 2, 2009
This may be dumb... but with 110k on the car and 15k on the engine, are you getting proper fuel pressure at the rails? Could be a partially clogged filter or a fuel pump on its way out. That's the only thing I can think of if the mpg dropped that fast with no recent mods to the engine. Might explain the "fuel cap" message also.
evolucion311
236
May 4, 2009
  • May 4, 2009
I got the fuel cap message a few summers ago. Then I got a CEL for EVAP Cannister Purge Valve stuck open.
Turns out it was a bad charcoal canister purge valve, which is located in the passenger fender well. It was about $35 from RockAuto and took 10 minutes to swap out.
If the purge valve's function is to inject gasoline fumes into the engine at start up. These fumes are evaporated gasoline from the fuel tank and are collected in the charcoal canister. If the valve is open, it will act just like having a faulty or missing gas tank filler cap: Your gas will evaporate and escape into the atmosphere. Depending on where you live, this may cause your car to fail a smog inspection.
I was evaporating a lot of $ in gasoline until I found this and fixed it. My MPGs rose immediately after swapping the valve.
If you suspect you have a similar problem, don't go to the dealer. At least try swapping the gas tank cap, purge valve, and check all fuel lines inch by inch visually and physically feeling them up with your fingers. The dealer will probably want to put the Rotunda (sp?) smoke machine on your car and charge you $400 in diagnostics and labor to replace a $40 part.
Go ahead and do what you can before the Stealership screws you. Good luck my friend.
HurricaneJesus
160
Springfield
May 4, 2009
  • May 4, 2009
But my car doesn't smell like gas....so that shouldn't be it, right?
HurricaneJesus
160
Springfield
May 26, 2009
  • May 26, 2009
Anyone know where to find the purge valve on an '02?
Pearl02
496
Kansas City
May 27, 2009
#10
  • May 27, 2009
  • #10
It should be inline with your EVAP cannister. I had to replace the one on my Mazda B4000 last yr. Pearl02.
jivepepper
776
Under a Sombrero. in WV.
May 27, 2009
#11
  • May 27, 2009
  • #11
Check for a vacuum leaks like a small hose off around the plenum. Especially the hose on the back of the plenum it goes to the fuel tank. Also look to see if they're just cracked.
Good luck.
A
agentl074
#12
  • May 27, 2009
  • #12
When my car had rough idle/surging/dying after in gear etc. after I cleaned out my MAS, throttle body...
...they had the PCM reflashed and reset the learning mode. Basically the ASE guys said that the PCM has a set of learning banks for idle mixture etc. and if your MAS was really dirty and you clean it out etc. that it has to adjust for it:
The PCM only adjusts one bank at a time and it needs to go up like five learning banks - just have your PCM learning mode reset and that should do it - if your problem is the same.
squeak93
2,309
387
164
Joplin, Missouri
May 27, 2009
#13
  • May 27, 2009
  • #13
Are you refering to your Keep Alive Memory (kam)? If so that is reset by simply unhooking your battery for 30 or so minutes (can step on the brake for 30-45 seconds directly after to shorten the wait time).
A
agentl074
#14
  • May 27, 2009
  • #14
Yeah that's it! :SNSign:
squeak93
2,309
387
164
Joplin, Missouri
May 27, 2009
#15
  • May 27, 2009
  • #15
No need to pay someone for something that you can do with a 1/2 in wrench and a little bit of time...
To the OP.... What did you clean the t/b with?
A
agentl074
#16
  • May 27, 2009
  • #16
So for future reference ... I just have to unhook the battery, step on the brake for 30 seconds and wait about a half hour? Or unhook battery, wait 30 min, step on break for 30 seconds and drive?
squeak93
2,309
387
164
Joplin, Missouri
May 28, 2009
#17
  • May 28, 2009
  • #17
On my car I only have to unhook the battery and then step right on the brake for 30 or so seconds. What that does it draing the battery reserve for the air bags and kam mem on the puter. usually I'll hook it back up after another minute or two just to ensure I got it all cleared.
A
agentl074
#18
  • May 28, 2009
  • #18
Cool thanks!
Spreadman
two wheels
Houston, TX
May 28, 2009
#19
  • May 28, 2009
  • #19
It could also be your idle air control motor is going bad. It's located on the front of the upper intake, behind the TB. Mine went bad and had similar symptoms.
bboylobo
130
Lancaster PA
May 28, 2009
#20
  • May 28, 2009
  • #20
NOS energy drink
1 of 2 Next Last
  • Gulftown980x
  • Jul 29, 2026
squeak93
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
L
Drivetrain 2000 GT High Idle - Pulling Out Hair - Help
  • lleonard1185
  • Jan 18, 2025
SN95 4.6L Mustang Tech Jun 4, 2025
Leo090
L
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
