As some of you may know royal purple sucks and from what I saw today its about the only thing it does well. Iam telling you guys this as warning about thier oils.
About two weeks ago my tranny started shifting wierd. At times it was hard to put into gear and others it was just fine. I figured that my clutch cable was stretched because the the stock adjuster was maxed out. I ended up replacing the cable last night becuase I had to muscle the shifter to make any gear changes. replacing the cable didnt help one bit so i decided to have the tranny fluid changed. I was standing under the car when the tech at pepboys took the drain plug out and OMFG. The tranny fluid was horrible, It seamed to have no viscosity at all, the stuff had the consistancy of WATER no joke and wouldnt even coad my fingers it just rolled of like water. I couldnt believe it. This stuff is total crap. I ended up having the guy replace the fluid with mobil1
my tranny shifts really smooth now with no noise at all.
The royal purple was barely in there 20k and now this. I will never use buy this stuff again and when i get back from colorado i will be taking the stuff out of my engine and rear-end.
kinda makes you think that if the tranny fluid is like this what are the diff and engine oils like?
my tranny shifts really smooth now with no noise at all. The royal purple was barely in there 20k and now this. I will never use buy this stuff again and when i get back from colorado i will be taking the stuff out of my engine and rear-end.
