royal purple in my car
95stang302
chicago
Hey guys whats up? I got a 95 gt wit 60,000 miles, and i was wondering if it would be ok to run ROYAL PURPLE in the engine, and trans?
Thanks.
P.S. I have stock 95 gt rims with the tires for sale in good shape. Tires have 1,500 miles on them.
I run RP in my GT. But sometimes the cleaners in full synthetic will expose a lewak that was blocked off by other crap. I found out my front seal was leaking after about a month of using RP. But i still use it .I just need to fix that leak.
yes if your car mechanically alright lol you can run it no problems haha if you do have little leaks it will def. show them to you haha i run royal purple everything in my 93.... it has a 160,000 and after i replace the rear main in the 94 i will problem be switching to rp in that also ..17x,xxx haha so no problems
I run Motorcraft sythtic blend 10w30 with MC FL1A filter. After doing a oil analysis it showed it was holding up great @ 5,000 mile oil changes, hell they want me to go 6,000 miles for my next oil change which I'm almost there. I'm sitting at 134,xxx runs strong. For a stockish 5.0 I would stick with Motorcraft syn/blend 10w30 or 5w20 great oils and fairly cheap.
I started using Mobil 1 Synthetic at 175k, wally world sells the 5qt jugs for 23$. Its really nice to only have to change your oil every 5-6k. And yes is will show any leaks you have, my real main seal leaks pretty bad so i have to add a qt at about 4k miles. Im still running strong at 193k.
Since we're having another which oil is the best thread... and I see that a lot of new oils are rated for 100000000 miles now, what are the filters rated for? Nobody ever talks about what the filters go till. And its pretty hard to change a filter without changing the oil...
Adam
