Royal Purple Mas ATF or SynchroMax?
crew_dawg16
445
DeKalb, IL
I've noticed there is a Max ATF and a Synchro Max manual transmission fluid from Royal Purple. My question is which should I use? The owners' manual says to use ATF, but is the Royal purple Synchro Max designed for this?
WTF? You are not answering his question, he asked which of the two to use, not your opinon on which brand. Dawg you want the synchromax, your tranny isnt going to break if you used the other but the synchromax is whats recomended. Thats what I use.
http://www.ttcautomotive.com/English/faq/faq.asp#14
Technical Questions
What type of lube is recommended for my TREMEC transmission?
The following types of lube are recommended:
TR-3550/TKO - GM Synchromesh or Dexron III
TR-3650/T-45/T-5 - Dexron III
T-56 (Ford and GM) - Dexron III
T-56 (Viper only) - Castrol Syntorque
