RPM Flutter, any suggestions?
1993SSP
1,194
Ky
Ok, in any gear, while keeping the RPM's right at 3K the tach will flutter and you can barely hear it in the engine. I have a NEW Accel Ignition, NEW accel coil. All NEW Internals and electronics on the distributor including cap and button, NEW plug wires and NEW Plugs, any other suggestions? On top of that it's all dyno tuned correctly, I am stumped and don't know what else to look for :mad:
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
attachment.php
attachment.php
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
