rpm goes up - car does not speed up.
  • Thread starter Thread starter dawakbar
  • Start date Start date Yesterday at 11:53 PM
D
dawakbar
Kuwait
  • Yesterday at 11:53 PM
good day all,
I am facing a problem with my Mustang gt 1988 auto transmission. the car runs well in all conditions except when Y turn the wheel right and press on the gas pedal heavily where rpm goes above 2, in this case, the car does not speed up while RPM keeps going up. it feels like transmission is going on neutral. I have to take my foot off gas pedal for a few seconds, and then press on the gas pedal slowly, then it will engage again and start running well. I changed transmission fluid and filter and checked fluid level already.
anyone familiar with this problem?
regards,
LILCBRA
Mod Dude
Dec 6, 2005
6,572
5,586
194
Corn County USA
Today at 3:20 AM
  • Today at 3:20 AM
If it's not a fluid level issue, it sounds like you're due for a transmission rebuild or there's some kind of seal that's been blown and the pump won't build pressure. AOD transmissions are also known for the cluster behind the pump losing a snap ring and grinding into the back of the pump. The fix is to replace the snap ring with a spiral snap ring. The theory is that the standard snap ring gives up at high RPMs. So if you end up having to open the transmission that would be something to keep in mind.
AeroCoupe
6,184
4,282
183
Claremore, OK
Today at 9:00 AM
  • Today at 9:00 AM
How does the transmission know the car is being turned to the right? Kinda weird that this is the only time this happens.
Reactions: General karthief
nickyb
I gotta say i never painted my nuts, Never Ever
3,039
1,666
163
nevada
Today at 9:31 AM
  • Today at 9:31 AM
I don't own an auto mine is manual ,that being said could the trans fluid lines get pinched when turning to the right???
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
K
Severe Drivetrain Shaking
  • KeithM412
  • Jul 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 29, 2025
AeroCoupe
N
Resolved High idle when warmed up that slowly comes down over 2-5 seconds...
  • NooStang
  • Jun 30, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 3, 2024
NooStang
N
C
1992 LX 2,3, automatic problems, oil dissapears.
  • Carpimp
  • Aug 10, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Aug 10, 2025
General karthief
