  • SN95 4.6L Mustang Tech
RPM Problem...
  • Thread starter Thread starter Speednlux
  • Start date Start date Jul 6, 2007
Speednlux
  • Jul 6, 2007
So I just picked up my car from the shop.
The intake manifold cracked due to high temp. and the car was leaking coolant badly. The previous owner used J-B weld and clued the hole shut and spray painted it black to match the color of the manifold. Either way, I had some exhaust work that needed to be done and that problem had to be taken care of as well...when I picked the car up today, as I'm driving home and throw the car in neutral on a roll the RPMs keep going up and down on their own. Not greatly but just a little bit, as though I was reving it up my self a little and then letting go of the throttle....either way I was wondering if anybody here knew what could lead to somthing like this occuring...
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jul 6, 2007
  • Jul 6, 2007
Could be the computer learning parameters again. Give a week or so and see if it goes away.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Engine 5.0 Head Gaskets installed wrong block coolant passages???
  • Xam Sirrah
  • Jul 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
Qtrhrse23
