rubber boot onto MGW
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
I was thinking today if I was suppose to put the rubber boot from the stock shifter on the MGW. Not the lower shift boot that bolts to the floor but the one on the stock shifter itself. The shifter right now is exposed to dust isn't it.
Yeah. I can see dust getting in the shifter and sticking to the grease thats in there. I think the rubber boot also helps with noise coming from under the car too. I'm confused... not the lower one with the gold bezel that bolts to the floor? Sorry its a monday.
Kevin
I must have miss read his post.. Roland please clarify for me.
The small rubber boot that keeps the road debris out of the interior?
Or
The leather boot cover that goes over the shifter handle?
Sorry man, I only remember the gold trimmed rubber boot that mounts to the trans tunnel. I reinstalled that one and then the leather boot cover. I don't remember a 3rd piece, but maybe a previous owner removed it?
The MGW does not require the little boot the was on the stock shifter. The lower boot (the one with the gold braket) cover the top of the shifter.
When you opened the box the MGW came in there should have been a small rubber grommet that goes around the bottom part of the handle. The grommet is thick and has a groove cut in the middle which the lower boot fits in to in order to seal off the pivot area of the shifter to keep dirt out of it.
If the lower boot is torn like mine was you'll have to get a new one. 50resto has them relatively cheap.
