Runin' Rich
Runnin' Rich
It starts up just fine and idle isn't too bad but sounds like it may have a cam in it. Just put on a new map sensor and it is still puttin' out black smoke. What are HEGOs? This is my first stang and I traded a 90 acura integra for it. It had no motor or tranny. I took (2) motors from a salvage yard and made (1) good one, I guess. It has all new gaskets but not injectors. Could it be those? I here they piss when at least one of them is bad instead of pulsate. Where do I pull codes from? I need help!!! It's gettin' cold soon and I need to park my GSXR.:bang:
If you have a vac leak, the HEGO [Heated Exhuast Gas Oxygen](O2, Lambda, whatever) sensor sees unburnt air,(lean) and pours fuel in to compensate. my 5.0L was leaking through a EGR delete plate and did the same thing.
Pull your plugs, and see if it's just one cylinder, or all of them that are rich.
Or- pull the codes - you can do it with the check engine light, (if equipped) and a piece of wire. if no Check engine light is present, use a test light or a volt meter. Or by a $5 code reader for OBD1 cars. some parts stores pull them for free.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
index.php
index.php
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
attachment.php
attachment.php
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Go through jrichker's post and pull codes to see whats up. I would then just start checking the most obvious things. Obviously you are getting a lot of fuel. Get an adjustable fuel pressure regulator and a pressure gauge to mount on the end of the fuel rail. I would check the injector function with a noid light to make sure they are all functioning correctly and none are stuck open.
Pull the oxygen sensors and check their condition...replace if they are looking rough. The O2's are going to be the main contributor to the air fuel ratio. As oxygen sensors get old they switch slower and therefore dont respond as quickly to changes in AFR. Let us know what you find
PS. The search function on this site is excellent, there are a lot of very experienced stangers who have posted some excellent testing and diagnostic information. Test first...replace parts second.
+1. o2's is what came to my mind
Runnin' Rich
Thanks guys. I bought a code scanner from Autozone for $30 and it narrowed it down to (4) possible solutions: Map Sensor, TPS Sensor, 02 Sensor and EGR Valve. All had been recently replaced except the EGR Valve so I hope that does the trick. I will post results by the weekend. Cross your fingers for me. Also, how do I put a pic of my stang on here and change my username?
When you get codes, post the actual code numbers. I have a complete list of the code definitions and what to check and test to fix them on 5.0 Mustangs.
