Runnin' Hot
  • Thread starter Thread starter 94ragtopGT
  • Start date Start date Apr 9, 2011
9
94ragtopGT
22
  • Apr 9, 2011
I just did a gt40 intake swap on my 94 5.0
Before the swap she would run on the O and R in the normal range but now shes in between the A and L in town and barely goes down on the highway.... any ideas on what the problem could be?? All help is appreciated!
Dino Dino Bambino
1,673
90
79
Cyprus
Apr 9, 2011
  • Apr 9, 2011
You could be getting false gauge readings due to a grounding problem. Did you reconnect the ground wire from the firewall to the intake?
9
94ragtopGT
22
  • Apr 11, 2011
bad sensor?
im not sure but i think i found the problem today. i have the gt40 upper and lower intake installed. on the front of the lower intake on the passenger side i have something threaded into it that is connected to a sensor. the sensor is pulled apart and broken. possible act or coolant sensor? i noticed the fan was not kicking on and im hoping its bc of the sensor. anyone know of the symptoms of the bad sensor? any info on the subject is a plus
9
94ragtopGT
22
  • Apr 11, 2011
Dino Dino Bambino
1,673
90
79
Cyprus
Apr 12, 2011
  • Apr 12, 2011
A pic of the sensor you're referring to would help.
toyman
1,944
54
79
Vernon BC
Apr 12, 2011
  • Apr 12, 2011
If it was the sensor above the T-stat housing that's the ECT. The dash gauge is on the other side on the intake behind and below the distributor and is a single wire. Grounding may be the reason the dash gauge reads differently.
9
94ragtopGT
22
  • Apr 12, 2011
It turns out that the temp sensor for the guage on the dash was not calibrated correctly and the coolant intake sensor that controls the fan got bumped during the swap. Replaced both and its running nice and cool now. Thanks for the help though!
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 10, 2026
AeroCoupe
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
351w turbo build.... Turbo guys teach me things...
  • Kid wita 5oh
  • Oct 22, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2025
General karthief
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
