  • 1994 - 1995 Specific Tech
running lean
  • Thread starter Thread starter spryd94vert
  • Start date Start date Apr 14, 2006
spryd94vert
  • Apr 14, 2006
i have an autometer air/fuel gauge on the a pilller and it never reads anything but lean, even at WOT. could the gauge be broke or am i just running completly lean. if so what are some things that i should look at to try and correct this problem. mods include BBK finder intake, cobra intake, GT40 heads, E303 cam headers full exhuast w/ no cats or emmsions. pls help!
bill302
2,131
alabama,gadsden
Apr 14, 2006
  • Apr 14, 2006
its your 02 sensors they will not read correct because you need wideband 02 sensors. welcome to stangnet...
spryd94vert
  • Apr 14, 2006
so you dont think that i am running lean?
bill302
2,131
alabama,gadsden
Apr 14, 2006
  • Apr 14, 2006
don't know but i know your guage is incorrect without wideband 02 sensors is you engine pinging at wide open throttle is your check engine light on?
spryd94vert
  • Apr 14, 2006
no there is no pinging, I knew that the gauge was not accurate but i figured that it would move off of lean once in a while.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Apr 14, 2006
  • Apr 14, 2006
What might cause you to run lean
let me count the ways jelly bean
1) GT comes from Ford kinda lean right off the bat
2) CAI could contribute
3) Still runnin the stocker fuel pump
4) Still runnin the stock inj's
There are four that quickly come to mind
If you got an afpr and its jacked up a god bit ...............
3 & 4 might not be hurting you too bad ... but still ......................
I would tell you to not be afraid to feed the beast with an ample supply of fuel
Even after saying all that ... I think it is strange you don't even see normal stuff when you are just putting around town
Grady
bill302
2,131
alabama,gadsden
Apr 14, 2006
  • Apr 14, 2006
you are probably good, if there is no pinging (detonation) also is check engine light on. and if your worried about a rich or lean condition you can install an adjustable fuel pressure regulator and tune it at a local dyno shop dynos usually run about $80 an hour. which is enough time to adjust fuel
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
