running lean
spryd94vert
i have an autometer air/fuel gauge on the a pilller and it never reads anything but lean, even at WOT. could the gauge be broke or am i just running completly lean. if so what are some things that i should look at to try and correct this problem. mods include BBK finder intake, cobra intake, GT40 heads, E303 cam headers full exhuast w/ no cats or emmsions. pls help!
What might cause you to run lean :shrug:
let me count the ways jelly bean :D
1) GT comes from Ford kinda lean right off the bat :(
2) CAI could contribute :shrug:
3) Still runnin the stocker fuel pump :nono:
4) Still runnin the stock inj's :nono:
There are four that quickly come to mind :)
If you got an afpr and its jacked up a god bit ...............
3 & 4 might not be hurting you too bad ... but still ......................
I would tell you to not be afraid to feed the beast with an ample supply of fuel :nice:
Even after saying all that ... I think it is strange you don't even see normal stuff when you are just putting around town :shrug:
Grady
you are probably good, if there is no pinging (detonation) also is check engine light on. and if your worried about a rich or lean condition you can install an adjustable fuel pressure regulator and tune it at a local dyno shop dynos usually run about $80 an hour. which is enough time to adjust fuel
