im kinda po'd about it.. why the hell does the car run lean immediately after i hit the throttle.. then it riches up a lil bit and saves itself.. then is strong again.. i adj the fpr like it should and it helped but not that much.. i have an h/c/i 24# injectors and all the bolt ons known to man.. could it be the tps sensor? someone hacked my harness and hardwired it in there.. i have a plug for the harness itself.. maybe replace it? i cleaned the IAC and no luck there.. it didnt do this before i built the motor.. what is the things to check in my cars case?
