Running rich
  • Thread starter Thread starter rock88gt
  • Start date Start date Oct 12, 2004
R
rock88gt
North Carolina
Oct 12, 2004
  • Oct 12, 2004
I'm pretty sure I know what the problem is but just want to get some ideas from people with more experience than myself. I can smell unburnt gas from the exhuast really badly and my gas mileage is crap. Is it possible that my engine is running to cool for everyday driving (barely reaching L) I have a be cool radiator and black magic fan. I'm not sure what thermo is in it but plan on putting in a new 180 anyways. Should I try disconnecting the fan and see if the engine get to op temp or what. Any ideas are greatly appreciated and thanks. I'm trying to help the gas mileage as much as possible for daily driving.
The car is an 88gt with mass air conversion
My mods if it helps: 306, gt40p heads, 1.6 rr's, e303cam, cobra upper and lower, 24#(around 35psi vacuum off), underdrive pulleys, msd6al, blaster coil, dynamod for distributor, I know there's a couple other things i'm leaving out, not sure if they matter with this problem
HISSIN50
34
129
Oct 12, 2004
  • Oct 12, 2004
pulled codes? checked the O2 values?
might need more info for something as widespread as you list. you can check the ECT and ACT values (JR has posted them in here). what kind of milage do you get?
good luck.
R
rock88gt
North Carolina
Oct 12, 2004
  • Oct 12, 2004
How do you check the o2 values? I'm getting around 120-140 miles to the tank and i treat my car like a baby most of the time
88GTtom
198
Woodbridge NJ
Oct 12, 2004
  • Oct 12, 2004
dam that sucks... i get about 280-300 to the tank. maybe your o2 sensors are bad.
R
Ray@VSK
355
  • Oct 12, 2004
Might need a computer off a newer stang that has mass air or you could try a fuel regulator.
dastang2
2,020
tx
Oct 12, 2004
  • Oct 12, 2004
i just went through something like this on my 95, check your spark plugs for a black sooty color. remember where they go. if you find one or 2 that ar black, switch the the corresponding injector to a cylinder that had a good spark plug. run the car for a while and then check the plugs again and if the black plug changed to the injector that you just moved, then you have an injector that is stuck open, you should go ahead and replace it rather than trying to use efi cleaner, that stuff does nothing.
U
usmc88gt
  • Oct 12, 2004
Thanks for the post guys. I just had the injectors checked, I'll try the computer thing and see if that works.
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
R
Engine Fox body doesn’t run hot until I start driving
  • Rose5oh
  • Mar 17, 2025
Fox 5.0 Mustang Tech Jun 7, 2025
limp
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
