What's up guys I've got a 1994 mustang gt that is having some issues. It's running rich and when it warms up sometimes on harder acceleration the engine just wants to die out and starts bogging. Normal driving is usually fine. Sometimes when it is about to die off on me while changing gears I press the clutch back in and the engine starts running again. Also in mornings when it's cold it'll idle up and down as well. My tacs don't work at the moment so I can't tell you the exact rpms it's running at on idle. I know the car has an egr delete as well. Tomorrow I'm going to try and give the air filter a clean. It has a bbk cold air intake.
Things I've done so far:
- cleaned maf
- new fuel pump
- new spark plugs
- new battery terminals
- ignition cylinder
Any other suggestions would be appreciated Cheers
- cleaned maf
- new fuel pump
- new spark plugs
- ignition cylinder
