  • SN95 4.6L Mustang Tech
Running slicks...
  • Thread starter Thread starter SilverBullet00
  • Start date Start date Jul 23, 2006
SilverBullet00
1,150
Wichita, KS
Jul 23, 2006
  • Jul 23, 2006
Another dissapointing night at the track leaves me wanting a set of slicks. It seems like the only prep the track well for the slick cars. I can hook up better on the street than I can at the track! So what do I need to run slicks? Im guessing im putting out about 280rwhp and 300rwtq, I know I would need a built rear end but would the stock t-45 handle it? Any and all suggestions welcomed.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jul 23, 2006
  • Jul 23, 2006
yeah the T-45 is not really that bad of a trans... it kicks the drap out of the T-5 that the old 5.0 cars came with.. If you do grenade it someday go with a TKO-600
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
Jul 23, 2006
  • Jul 23, 2006
31 spline axles, and matching posi.
Y
Yellow2002GT
148
Raeford, NC/ FT Bragg
Jul 23, 2006
  • Jul 23, 2006
If you want to hook up....just get a set of MT DR's....but the secret is to set them at 14PSI but not lower than 10PSI......My last track outing I was at 17PSI when I first ran and only cut a 1.98 60ft...then dropped to 15 PSI and cut 1.90.....adjusted it again to 13 PSI and a good 2nd gear burn out and 1.71 was rewarded.....no track prep was done for at least 3 hours and alot of street tires were running! Tire pressure on DR's makes all the difference in the world! On my last run I put them to 32 PSI to drive home and my buddie wanted to run one last time......only cut a 2.2 60ft with MT DR's set that high! Just have to find your sweet spot for your tire pressure and set up!
"ED"
C
cronin49
Banned
Aug 12, 2003
432
SC
Jul 23, 2006
  • Jul 23, 2006
never mind
BooWFO
991
Louisville, KY
Jul 24, 2006
  • Jul 24, 2006
NEED - a set of rims and tires.
Good idea - 31 splines and diff.
I ran the last part of last season sprayin outta the hole on mt et streets (bias ply) on the stock axles and diff. I've seen 3 stock diffs let go in the same amount of time on cars that make the same or less power with dr's.
SilverBullet00
1,150
Wichita, KS
Jul 24, 2006
  • Jul 24, 2006
sweet! I know my next step is to get some 4.10's, but while they have it apart I might as well build up the rear end
damacman
529
Phoenix, AZ
Jul 25, 2006
  • Jul 25, 2006
Very little sidewall deflection on 17" DRs . . . sure wish someone would have told me that before I blew mine up . . .
SilverBullet00
1,150
Wichita, KS
Jul 28, 2006
  • Jul 28, 2006
How much abuse can the t-45 put up with? If I get a built rear end do I have to worry about my trans with the power Im puting out?
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
Drive Shaft/Rear Diff Issue on 2014 GT
  • DudeStang
  • Jun 16, 2025
  • 2010 - 2014 Specific Tech
2K
2010 - 2014 Specific Tech Jan 21, 2026
gkomo
