i just installed new parts on the motor
new ,heads( gt40x ) ,cam( e303) , chain , upper and lower intake(trick flow track heat ),throttle body and egr (70mm)
,mass air 24 lbs( c&l ) and 24 lbs injectors and o2 sensor 's
i just got the motor to run with some help of guys on this site ( thank you )
by adjusting the adjusting bolt on the throttle body
and i also cleaned the iac on the throttle body
but it run like crap
it sputers at a higher rpm when driving
and seem's like the timing moves up on its own when i put the spout back on
anything that i missed ?
