rusty water in cooling system
alright, guys, having some cooling issues.
ccrm was bad, so that was replaced. fans (both speeds) seem to be coming on at the specified temps in my tweecer, but there is a problem:
the radiator was clogged. the high-speed fan would be on, but the air was blowing cold while the temp of the coolant at the upper hose was really hot.
thermostat was also replaced.
had the radiator flushed out at a radiator shop. cooling worked after than, though a couple hours later the high fan was on, the air was blowing cool, and the temp of the coolant in the hoses was really hot.
i'm thinking all the rusty water that stayed in the block is going to clog the radiator again.
my question: is there a way to flush ALL the crap out of the block and radiator?
i'm thinking if i remove the thermostat and disconnect the lower hose at the water pump, i can flush it all out while the car is running while stickign a garden hose at the top of the radiator until the water runs clear.
thoughts? suggestions? opinions?
thanks, gents.
thanks, gents.
