- Aug 21, 2006
- 10
- 0
- 0
I plan on building a stock bottom end 306 in the next couple weeks and needed some advice on some parts to go with.
what cam would you recommend i run? i will be running the holley systeMAX heads and edelbrock performer intake and want to get somethin to go good with this setup but still have at least a small chance of smogging...... california FTL.... not really toooo worried about this as i have my ways of passing tho
have heard goos things about the TFS stage 1 and the AFM N-61 (I think thats the one) but would they be a good match?
Also what do you guys recommend in the way of pistons? defiantely going forged but dont know if i will need to go flycut or not. I want to raise the compression but what will be safe with my heads and cam? Dont know if i should run 1.7 or 1.6 roller rockers either, i guess it depends on the cam.
any input on my build up will be greatly appreciated as im pretty lost in how to get a good setup that will work together and make good power
thanx
:SNSign:
have heard goos things about the TFS stage 1 and the AFM N-61 (I think thats the one) but would they be a good match?Also what do you guys recommend in the way of pistons? defiantely going forged but dont know if i will need to go flycut or not. I want to raise the compression but what will be safe with my heads and cam? Dont know if i should run 1.7 or 1.6 roller rockers either, i guess it depends on the cam.
thanx
:SNSign:
