Screw In Intake Temp Sensor
not sure if this will help but I work on conrtuction equipment and as long as you stay with the same wire input ex 2 wires into plug you will be fine with a 2 wire replacement screw in. I swap out alot of differnt sensors and as long as the format is the same IE 1 wire, 2 wire etc the sensors work. Field work requires me to be creative.
