SCT 4 Banks Chip
crazystang05
172
Ok I am so mad at Modulardepot right now. I orderd my chip and it took them 2 weeks before they even shipped it. Then I finally got it, and they did not give me any information about the tune or even what position the tune was on. Assuming it was on 0 the position the chip came with. I started the car it would start and with in a second stalls out. I turned the chip to the # 4 position which is the stock program and the car starts and runs fine. What is wrong? :bang: please help thanks
Just call or e-mail and tell them what the problem is, they should be able to e-mail or fax you the info you need. I found them great to deal with.
0 on my chip is tune #1
1...................tune #2
2...................tune #3
3...................no run [won't start]
4.................stock tune
what are the different types of tunes that you have?
0) custom tune with stock timing
1) custom tune with timing bumped
2) custom tune with timing backed off -2 degrees from stock [ for using nitrous or if I find myself needing to use 87 octane as I have the raised compression b/c of the PI swap]
4) stock tune
